Tyvek paper
Finishes, paints and coatings
Tyvek paper
Postby Rasmateo » Sat Jan 28, 2017 4:31 pm
Has any one tried putting tyvek paper on the wood exterior before skinning with aluminum, or a s this a dumb idea?
Rasmateo
Re: Tyvek paper
Postby dmdc411 » Sat Jan 28, 2017 8:00 pm
My opinion, it won't matter. Tyvek sheds water, it's a directional fiber. The aluminum skin will seal, the plywood, except from below. Shedding water also. As long as you seal the edges correctly.
dmdc411
Re: Tyvek paper
Postby Rasmateo » Sat Jan 28, 2017 8:04 pm
My friend has some extra tyvek and I thought it would be one more barrier just in case.
Rasmateo
Re: Tyvek paper
Postby prohandyman » Sun Jan 29, 2017 7:29 am
Yes used it on the roof of this camper...never did it before on the previous 29 campers. Had it left over form a job and wanted to use it up. Don't know i if it helps or not. Probably at least smooths a few irregularities out some. Obviously did not use it on the sides, which is what it designed for, verticle not horizontal but hey I am a rebel!
116083
Dan
prohandyman
Images: 785
Re: Tyvek paper
Postby Rasmateo » Sun Jan 29, 2017 12:47 pm
Thanks for the info guys, I have it so might try it.
Rasmateo
Re: Tyvek paper
Postby Gator417 » Wed Feb 15, 2017 2:00 am
Its a great idea. Unlke plywood, Tyvek is made to be used on the exterior of buildings. Its a natural vapor barrier and won't wick moisture, like plywood. Its also thermally stable, so it won't expand and contract with changes in heat and humidity, like plywood. If it is wrapped around the bottom of the plywood, it may help keep moisture out, especially if you seal it with a urethane or similar finish.
Good luck,
Gator
"Aluminum skinning is to cover rotting prone crappy plywood"
linuxmanxxx
Gator417
Re: Tyvek paper
Postby tony.latham » Wed Feb 15, 2017 11:25 am
I'm not saying it's a dumb idea, just not sure what it's function would be. Thoughts as to it's mission?
Seal your plywood exterior with The Mix or better yet, epoxy before you apply you're aluminum/trim/sealant and your camper should outlast you.
Return to Skinning secrets
