What alloy is best for skinning with aluminum?
Finishes, paints and coatings
Postby Scottsinky » Wed Apr 19, 2017 11:12 am
I have found a source for sheets or rolled aluminum in Wisconsin but I need to know what alloy I should order. I'm hoping to get a little help from the experts. I am wondering which alloy is resistant to denting yet is flexible enough to form around the curves of my camper. Oh and also doesn't break the bank. I am thinking .040" or .050" thickness
Thanks,
Scott
Scottsinky
Re: What alloy is best for skinning with aluminum?
Postby Aguyfromohio » Wed Apr 19, 2017 3:25 pm
I'm not sure the alloy is really that important for trailer skins.
Back when I designed machine parts we made alloy choices to consider strength, or machinability, or resistance to galling, or weldability, or the ability to get a clean edge on holes punched in panels, or the ability to be stamped into deep draws without cracking.
Most aluminum alloys have two numbers The first four specify the metallurgy, and the last bit specifies the hardness from heat treating or other processes.
The alloy 2024, for example, is available as 2024 -0, 2024 -T3, 2024-T4, and 2024-T351
Some are annealed, some are heat treated, some are age-hardened.
None of that stuff matters very much in a cosmetic teardrop skin, unless you are bonding it and stressing it and need to know it's strength pretty accurately.
I believe 2024 T-3 is the most popular choice for airstream exterior builds and repairs.
I'm shopping for prepainted aluminum skins for our build now, and I'm completely ignoring the alloy info.
Aguyfromohio
Images: 76
Postby Andrew Herrick » Wed Apr 19, 2017 3:54 pm
3003 is the standard. Easy to form and machine, but scratches easily. One of the most common alloys, and probably the cheapest.
All the prepainted aluminum panels I've used are 3105. No complaints there!
I've never used/seen 2024 used on a teardrop. I think it has pretty low corrosion resistance for aluminum.
5005 is anodizing quality aluminum. Better corrosion resistance and strength than 3003.
5052 is like a "premium" upgrade to 3003. Stronger, more dent resistance, better corrosion resistance, etc. It's more expensive than 3003, but not hugely. Harder to find, though.
6061 is structural strength aluminum. Very pricey. Does not easily bend over tight curves.
What thickness you specify for your skin depends partially on how you attach it to your wall. Assuming you're not doing anything funky with your walls or roof, I would say that 0.040 thickness is all you need. Even 0.032 works extremely well. The only reason I would go thicker is if you're using the skin for structural strength or building a rock-crawler.
A few of my builds:
SEE MORE AT: boondockcampers.com
Andrew Herrick
Images: 15
Postby dmdc411 » Wed Apr 19, 2017 10:30 pm
I can say 2024 T3 is heat treated and used in aviation for aircraft. 2024-O is annealed. It's in a soft condition, requiring heated to a set temperature and allowed to set before it reaches T-3 state. T-351 I thought was extruded, not sure. 2024 is expensive. 6061 and I think 5052 are weldable. 3000 series is what I recall is also known as refrigeration aluminum. I used it to cover my tear. It cheaper, $60 for 4 x 8 sheet. Hope this helps!!
Sent from my SAMSUNG-SM-G870A using Tapatalk
dmdc411
Postby Scottsinky » Thu Apr 20, 2017 9:07 am
Thank you for the outstanding advise. That helps a ton! Also for the quick responses :thumbsup:
Scottsinky
Postby Wildfire » Wed Jun 07, 2017 4:47 pm
3003 will shine better if you want to polish it. 5052 will always have a "dull" look by comparison (but you'd have to have them side by side to tell the difference)
5005 anodized is probably the best from an aesthetic point of view. Looks good going on and will stay that way due to the clear anodizing.
Wildfire
Postby joecreep » Fri Jul 19, 2019 7:13 pm
It also depends upon what size sheets you need. I chose 5052 because I could get 5' x 10' and 4' x 8' sheets. The thinnest I could get in a 5' x 10' sheet was 0.050". With the Trump trade wars, I paid $150 for the 5' x 10' and $75 for the 4' x 8'. I tried to wait the trade wars out, but my project had a trip it needed to be done for so I had to bite the bullet. The 5052 is supposed to be a bit more corrosion resistant. Seeing as this is my first build, I do not have much to compare it to.
If anyone needs an aluminum supplier in Sacramento, CA, check out http://www.cardoindustries.com/ on El Camino Ave. It's a small mom/pop (well only pop in this case)
place that sells all types of aluminum stock. He had to order the 5' x 10' sheet but it only took two days, other sheets were in stock. Nice guy, he really helped me out with securing onto a small pickup without bending the sheets.
I know this is late to the show and you're probably already done. Just food for thought for other newbies like me prowling this forum.
Just my two cents and good luck.
joecreep
Return to Skinning secrets
