Page 1 of 1
Painting over PMF?
Posted:
Mon Sep 16, 2019 12:25 pm
by Sanuk.Sanan
Hi again,
I'm considering painting over my teardrop so it matches my car. Is it possible to paint over PMF? If so, what kind of paint would you recommend? external, industrial, auto?
Thanks again for your help!
Julie in SoCal
Re: Painting over PMF?
Posted:
Mon Sep 16, 2019 12:36 pm
by Pmullen503
PMF is typically painted with latex house paint.
Posted:
Mon Sep 16, 2019 12:44 pm
by Sanuk.Sanan
You're the best PMullen!
Thank you!
Julie
Posted:
Mon Sep 16, 2019 2:21 pm
by RJ Howell
I'm in the process of doing just that, painting my PMF (canvas). As far as matching your TV color, that's going to be using samples and matching as close as possible. Ya, that's what I tried.. Seems that you can get a solvent based paint easily to match, yet turning that to a water based is difficult (as I have so learned).
I'm not certain how a solvent based paint would react of TB2. I used a quality water based primer to attach my canvas (PMF). That means stay water based for me for best results. As means using chip samples to get close.
Another approach is to go to a Automotive Paint supply and see if you can get a sample chip. My TV is too old and they don't carry chips for it anymore. This would give you a way to get a custom mix that would be very close.
Curious, have you already bought your canvas and attached?
Posted:
Mon Sep 16, 2019 2:23 pm
by RJ Howell
RJ Howell wrote:I'm in the process of doing just that, painting my PMF (canvas). As far as matching your TV color, that's going to be using samples and matching as close as possible. Ya, that's what I tried.. Seems that you can get a solvent based paint easily to match, yet turning that to a water based is difficult (as I have so learned).
I'm not certain how a solvent based paint would react of TB2. I used a quality water based primer to attach my canvas (PMF). That means stay water based for me for best results. As means using chip samples to get close. Strange I can still buy the paint (solvent based) yet can't get a sample chip..
Posted:
Mon Sep 16, 2019 2:40 pm
by Sanuk.Sanan
Hi There RJ,
My canvas is already attached and probably has been for 10 years.
Sorry, you're having such a difficult time. I have a newer Subaru Forester and so I've been researching hex color codes for it. I'm thinking I might be able to go to Home Depot or Lowes and have them custom mix it to the hex code. This was my thinking anyway. I'll let you know how it works.
Julie in SoCal
Posted:
Mon Sep 16, 2019 3:04 pm
by RJ Howell
Do hope that works for you! Happy travels!
Posted:
Mon Sep 16, 2019 5:33 pm
by John61CT
Get a range of small quanity mix samples and test. Final color after drying, a bit of weathering will vary a lot, that way you can "dial it in"
Posted:
Mon Sep 16, 2019 8:54 pm
by Pmullen503
Places like Lowe's or home Depot can match if you can bring in a sample of your car paint. The gas cap door can often be removed without too much drama and used as your sample.
You can also buy small bottles of touch up paint to match your car and can paint a sample with that.
Posted:
Tue Sep 17, 2019 3:58 pm
by Sanuk.Sanan
Thank you! This is perfect. I have some touch-up paint I can use to create a "chip"
Julie
