Wrapping PMF....
Finishes, paints and coatings
Wrapping PMF....
Postby MJWBuffalo » Fri Jan 31, 2020 11:09 am
So I decided on PMF after reading literally hundreds of pages here. I am satisfied that the process of painting "the mix" on the plywood, TBII, high quality canvas combined with lots of coats of good exterior paint and sanding can leave a lightweight, tough, waterproof surface that is also pretty smooth. I like that is gets me the desired result while going easy on the budget and being incredibly DIY friendly.
Here's the parts I haven't seen answered.... how much do I wrap? Like I understand that I overlap the corners and then wrap the roof down over the walls. But do I have also wrap inside the door and window openings? Can I wrap the whole thing in vinyl afterwards? Will it stick?
I am using my DIY Standie as a food trailer and will need some flashy graphics or at least a snazzy paint job that will help me stand out from the crowd
Thanks
Matt
MJWBuffalo
Re: Wrapping PMF....
Postby Pmullen503 » Fri Jan 31, 2020 1:23 pm
Vinyl wrap works best on a smooth surface. It might stick to PMF finished with glossy paint but you should test to see if it looks the way you want.
Pmullen503
Images: 67
Postby rjgimp » Sat Feb 01, 2020 1:20 am
Yep. When in doubt, test it out! :D
-Rob
rjgimp
Images: 7
Return to Skinning secrets
