Titebond III on top Titebond II
Finishes, paints and coatings
Postby maulte » Wed May 13, 2020 10:46 am
I got two Gallons of Titebond 2. I am thinking I will need at least two gallons more. There appears to be a shortage of Titebond 2 in Canada right now and ordering online will be $100/Gallon(with duties and shipping). I can get Titebond 3. If do PMF base coat with Titebond 2 can I put Titebond 3 as the second layer, or will it stick to each other? Or can I Mix Titebond 2 and Titebond 3 together make Titebond 2.5 :-)
maulte
Re: Titebond III on top Titebond II
Postby tony.latham » Wed May 13, 2020 9:25 pm
Dried Tightbond 3 doesn't stick to itself. Tightbond 2 does adhere to itself.
At least, that's what Tightbond has said in the past. I don't think you want to mix it, but I'm guessing.
$100/gallon sure takes the P out of PMF. :frightened:
Postby maulte » Thu May 14, 2020 5:28 am
My only other options is to use 2 gallons of Titebond 2 I already have do 50/50 of water and glue so spread it out further. Then just put extra paint on it.
maulte
Postby nbcarey » Wed May 27, 2020 11:58 pm
You might want to read this write up on how repairable different glues are. "Reparable" in this case meaning, "How well does it stick to older gluelines, either the same glue or different glues?"
http://forum.woodenboat.com/showthread. ... Repairable
[sorry about the bit rot on some f the photos in that link. It's been a few years.]
TL;DR — Nothing really sticks to cured PVA glues, except for good epoxy, including other PVA glues. TiteBond, TiteBond II, and TiteBond III are all PVA (polyvinyl acetate) glues.
nbcarey
Postby pchast » Thu May 28, 2020 8:29 pm
Sorry, I just saw this..........
Test but, inho, use any good quality latex paint.
It should work well enough for the application. :thumbsup:
pchast
Images: 97
Postby ArtMini » Tue Sep 29, 2020 9:45 pm
I can tell you this much about Titebond. When you glue two pieces of wood together it's never coming apart. All of my build I glued and screwed everything together. I made a mistake and 15 minutes later it wouldn't come apart. Ended up ripping a layer of plywood off. I'm giving Titebond 2 thumbs up lol
HAVE FUN STORMING THE CASTLE!!!!
ArtMini
Images: 16
Return to Skinning secrets
