I directed this to Aussies orginally. I figured there was not much point asking the mainly American membership about their paint preferences when I was unlikely to find too many US brands here. No Gripper for instance.
However, I have since done some research on primers and it looks like some products supplied by Rustoleum Australia would be good.
I remembered the local paint store has quite a range of Rustoleum pains, so I went there this morning and found they have some of the Zinsser range of prep coats (these come via Rustoleum Australia).
I explained to the guy that I had really soaked my timber with polyurethane, and that it wasn't laziness making me reluctant to sand, rather that I really would prefer not to so as have more confidence in the seal on the timber.
So we looked at the primers on offer.
The Smart Prime datasheet says it has excellent adhesion to enamel paints and varnishes.
The Bulls-eye 1-2-3 looks OK too. Both say to not use on decks, areas subject to immersion or in prolonged contact with water.
The Bulls-eye 1-2-3 datasheets says it "provides excellent adhesion to dense glossy surfaces, enamel paints and varnishes, panelling, laminates and ceramics without sanding or deglossing."
I find that statement very appealing
Just requiring a wash and degrease floats my boat.
Datasheet also says it's suitable for any topcoat.
Has anyone used it? Had problems with it, etc?
They are all $50 per litre or $105 per US gallon.
I figured 1 litre won't be enough so a gallon can is the go.
Sounds expensive, but its local convenience (could save $18 buying at Bunnings in Adelaide, but that's a long way away), and ordinary house primer runs $70 per gallon.
Thoughts anyone?
- Primers.JPG (154.59 KiB) Viewed 2972 times
