Fiberglass sheets
Finishes, paints and coatings
Fiberglass sheets
Postby Kim Armstrong » Tue Mar 08, 2022 3:28 pm
Would like your input on some fiberglass sheets. I found some sheets for sale and no one knows what they are used for. They are 5x8 and .040-.050 thick. Semi transparant no gelcoat and flexibly probably can be bent around a 6-8" curve. I didn't want to spend alot of time fooling with the stuff if you all thought it was not a good idea. I would just "float" it like filon or aluminum and paint it cause I don't know if it is uv safe. Or will I be better off just glassing the wood and paint? Thanks
Kim Armstrong
Re: Fiberglass sheets
Postby tony.latham » Tue Mar 08, 2022 3:50 pm
...and no one knows what they are used for.
Well... I wouldn't use something that I didn't know what it was... That's my 2¢. I know you think it's fiberglass and it may be. But without knowing what it was made for, I would stay away from it.
:frightened:
Postby Kim Armstrong » Tue Mar 08, 2022 5:29 pm
Thanks Tony. I was hoping you would would chime in. They are $11.00. Thought they might speed things up.
Kim Armstrong
Postby saywhatthat » Wed Mar 09, 2022 3:32 pm
I know a tiny bit about fiberglass. are they from translucent panels from a semi-truck trailer? can you find any stamp from manufacturer or card late into the fiberglass. are there any strings at the end that looks like they use woven in it . what dose the two surfaces look like. a picture would be great
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby Kim Armstrong » Mon Mar 14, 2022 6:20 am
Sorry just getting back to you. There are no strings on the edges. You can some what see your hand thru it. I didn't get a picture of it but was thinking they might use it on big trucks or the roof on ups trucks. They are real fexible.
Kim Armstrong
Postby saywhatthat » Mon Mar 14, 2022 10:11 am
if you can take some rubbing alcohol and clean real good get the tiny spot put some fingernail polish on it dose it bound .yeah I'm betting they're either Greenhouse panels or off of a truck trailer
saywhatthat
Images: 135
Postby rjgimp » Mon Mar 14, 2022 3:29 pm
:frightened:
Tony short changes himself. The advice he only puts a 2 cent label on should cost at least a nickel! :applause:
-Rob
rjgimp
Images: 7
Postby Kim Armstrong » Sat Mar 19, 2022 2:24 pm
Yea they some what look like light panels they put in the tops of trailers and ups trucks. Thanks
Kim Armstrong
Return to Skinning secrets
