PMF + Raptor Liner
Finishes, paints and coatings
PMF + Raptor Liner
Postby camhum » Thu Mar 31, 2022 2:00 pm
Hi everyone,
I'm trying to decide how to stiffen up my plywood before applying Raptor Liner on the outside. I looked into fibre glassing and it seems slightly pricey so I was wondering if anyone has done poor mans fibre glass and then applied raptor liner on top? Or looking for any suggestions on the best way to prep for Raptor Liner so it wont crack because of the wood flexing.
camhum
Re: PMF + Raptor Liner
Postby John61CT » Fri Apr 01, 2022 2:21 pm
Not canvas too flexy.
Substrate really does need to be rigid.
Better IMO to find a coating that is more flexible.
John61CT
Postby twisted lines » Fri Apr 01, 2022 5:57 pm
Monsterliner sticks very well to Clear gloss Polyurethane, thats sanded and wiped down with MEK.
I will be layering inside & outside foam with 1/8" ply prior, to the 3 clear gloss poly coat's sanded and wiped down before each layer.
Maybe next month.
Approved on my first one. ;)
Recommended by MFG.
Racking up; And Rapin foam
twisted lines
Return to Skinning secrets
