Im going to use 40mm sandwich panels, bit want to have both sides covered with gelcoat so that no foam from the core is visible, at the same time get the best strenght as possible.
Any smart way to cut this to make it fit like this?
cineview wrote:Im going to use 40mm sandwich panels, bit want to have both sides covered with gelcoat so that no foam from the core is visible, at the same time get the best strenght as possible.
