Pod #2 flat packed and assembled at the church...
A place to talk about homeless shelters, design and construction. (No politics)
Postby mikeschn » Sun Nov 17, 2013 3:36 pm
Pod #2
Flat packed down to the church in Indiana and assembled by some of the members in about 24 minutes or so...
Put the ends on and dropped the spars in...
This is how it looks with all the spars dropped in and screwed into place... (shop pic)
The insulation is embedded in between the spars and the skins...
Side skin going on...
Roof is going on...
Church members checking out the pod...
Pods set up on site...
Images: 479
Re: Pod #2 flat packed and assembled at the church...
Postby Miriam C. » Tue Nov 19, 2013 12:11 pm
This is great! Do you have a cost on these. I wonder if our local shelters would consider them.
Note: Holes need some screen wire to keep out insects!
Postby mikeschn » Tue Nov 19, 2013 4:30 pm
Miriam C. wrote:This is great! Do you have a cost on these. I wonder if our local shelters would consider them.
Hi Miriam,
And thanks! As for the cost, without paint under $200. Currently the design has too many curves to be very easy to build. And too many notches.
So I am thinking about a design with 5° straight angled walls, and just a slight curve on the top. If local shelters can build them quickly, they might consider it. Maybe I should go back to considering a lean-to type roof?
P.S. re the screen mesh to cover the holes, you're right. I have some here. Maybe I'll make some screens, and mail them down there.
Images: 479
Postby Miriam C. » Wed Nov 20, 2013 11:34 pm
I used a industrial double sided tape to put mine on. Worked great and they help keep any wind blown water out. I think your design is great because it leaves room for wide shoulders sitting up. :D
Postby crumbruiser » Sun Nov 24, 2013 10:41 am
Mike, This is such a good thing you're doing. I haven't been in depth on the forum for a while and just discovered this. You are doing such a good thing! :applause:
Frank
I am not weird, I am a Limited Edition.
Facebook http://www.facebook.com/profile.php?id=100000303236631
crumbruiser
Images: 255
Postby 48Rob » Tue Jan 07, 2014 8:41 am
Mike,
Are the shelters in use?
Any reports from the occupants as to how they are working out in this cold weather?
Rob
48Rob
Return to Homeless Shelter Design & Construction
