trailer hitch for 2005 ford focus.
All about towing and tow vehicles
Re: trailer hitch for 2005 ford focus.
Postby Gage » Thu Jun 26, 2014 12:26 am
etrailer.com has several hitches for the Ford Focus at $131. :thinking:
http://www.etrailer.com/hitch-2005_Ford_Focus.htm
Image Image Image
Gage
Images: 28
Postby rainjer » Thu Jun 26, 2014 12:36 am
Max tow capacity 1000#.
rainjer
King Koleman
Images: 11
Postby bobhenry » Thu Jun 26, 2014 5:52 am
Suzuki Esteem Not rated to tow.
Had to order a custom hitch thru Drawtite.
I have move most of my home with this little car.
It has hauled 1300# of drywall
Even more lumber and it gets 32 to 35 MPG while doing it :D
Images: 2617
Postby rowerwet » Thu Jun 26, 2014 6:53 am
I found a Reese hitch assembly for my 2001 Focus at a local discount store for $20. the hitch assembly through bolts to the spare tire well at a couple of points and also has two U shackles that go through the metal rear bumper (yes there is a metal channel inside all that plastic and foam) I installed it myself in a couple hours, and even used some of the extra parts in the kit to reinforce the wheel well mount a bit more.
In the US the Focus did not change until 2012, so the hitch assembly is the same 01-11.
The Focus had the lower powered engine (single valve intake) but it was never lacking for power, even when towing my tear.
I miss that car, we sold it with over 250,000 miles on it, and it just finally when to the scrapper with over 300,000 miles on it. the clutch finally died and it wasn't worth fixing. It still had the original timing chain, and never needed much work other than the brakes and oil. The rh cv shaft seal leaked from the tranny, so I had to top off the tranny oil each year. You can't beat a car that gets 35 mpg and only cost $10k new.
rowerwet
Images: 521
Postby mezmo » Thu Jun 26, 2014 6:40 pm
U-Haul would also probably be able to fit you out.
mezmo
Images: 194
Return to Towing and Tow Vehicles
