Tow Vehicle possibilities Best Mileage-Hybrids?
All about towing and tow vehicles
Re: Tow Vehicle possibilities Best Mileage-Hybrids?
Postby DrewsBrews » Tue Sep 08, 2015 8:45 am
catinmoon wrote:
DrewsBrews wrote:Ever consider raising the rear of the legacy? http://www.rallitek.com/lift-kits/6361-rallitek-rear-lift-kit-all-impreza-2008-2014-legacy-2000-2009-outback-2000-2009-baja-2003-2006.html
Scraping the receiver isn't the end of the world. Unnerving yes, but usually not a big deal. Scraping the trailer however is no good. If the trailer is angled up when hitched to the truck, that points the rear of the trailer down and would explain the rear end scraping. This can be altered with different raise/drop on the ball mount on any vehicle.
Hi again, from Stephanie
Delayed reaction, but I am getting back to this idea. I see on the website they have both a front and a rear lift kit. I just need more clearance so wonder if raising both front and rear makes sense? thanks
Raising the front wouldn't really affect towing clearance, but if you find you need front end clearance on a day to day basis then I don't see why not. However, also factor in that when you make these type of changes, especially in the front end, it will affect the alignment angles. So getting an alignment done after the lift is installed is highly recommended.
DrewsBrews
Postby Chaverim » Fri Aug 10, 2018 11:24 am
I know this is an old thread, but hybrid vehicles and electric vehicles have been on the rise as well. I just joined the forum and I am using an Audi A3 e-tron (plug-in hybrid) to tow a T@G Sofitel. I have only towed it once, but now I'm getting ready to do a multi-day trip all the way from AZ to MT and across to ND then down in to Denver CO. We will see what type of mileage I get. I hope I get above 20 as I normally get 35 on the highway at 80mph and only have a 10gal tank.
Mike
Chaverim Basenjis
2018 T@G Sofitel
2016 Audi A3 e-tron
Chaverim
Postby catinmoon » Fri Aug 10, 2018 12:04 pm
Let us know how your trip goes, sounds like a nice route. I have been watching this thread for a while and realize that things are changing in the vehicle world. Now we drive computers on wheels. Best,
Stephanie
Chaverim wrote:I know this is an old thread, but hybrid vehicles and electric vehicles have been on the rise as well. I just joined the forum and I am using an Audi A3 e-tron (plug-in hybrid) to tow a T@G Sofitel. I have only towed it once, but now I'm getting ready to do a multi-day trip all the way from AZ to MT and across to ND then down in to Denver CO. We will see what type of mileage I get. I hope I get above 20 as I normally get 35 on the highway at 80mph and only have a 10gal tank.
catinmoon
Images: 10
Postby pfennigcat » Fri Aug 10, 2018 3:19 pm
My Outlander PHEV (purchased in Jan) has towed Wee Frilly (my somewhat teardrop whale) from Austin TX to Durango CO (over 7k ft elevation). I wasn't actually calculating by hand every fill-up, but if I trusted the onboard computer I was getting about 18 mpg most of the time between 65 and 70 mph. Less on the way there, more on the way back. The Outlander PHEV does have an official tow rating (1500 lbs) and my trailer probably totalled around 600 lbs (half trailer, half whale and tents and pillows, just guessing). My trailer is pretty high off the ground, I would likely get better aerodynamics if I were on a lower platform.
Like the audi etron mentioned above, I have a small gas tank by normal standards, 12 gallons. In west Texas, on I-10 on the way back, very nearly ran out of gas as there were great stretches between fuel.
We weren't (and probably wont be) boondocking, so the fact that the PHEV can act as a generator and battery bank wasn't as useful as I had thought. On the other hand, I could get a full battery (~22 miles worth, without the trailer) each night for exploring/shopping/etc.
Unlike some other hybrids, the Outlander PHEV has no transmission -- it's electric-drive all the time (with a single clutch that can engage the engine to the front wheels above 42 mph). Between that and the official tow rating, I didn't worry about the vehicle being overloaded in any way. Works great for me so far.
pfennigcat
Postby Chaverim » Tue Aug 14, 2018 7:40 pm
Well, the trip started off bad due to a puncture in the to vehicle, but now the trip is going well. My 1.4L 4 cyl plug in hybrid is getting about 21mpg going from phoenix metro AZ to the 4 corners and up through the mountains of CO to Denver.
Mike
Chaverim Basenjis
2018 T@G Sofitel
2016 Audi A3 e-tron
Chaverim
Postby friz » Tue Aug 14, 2018 8:33 pm
I get close to 30 mpg towing my #500 lb tear with my 2014 Ford Focus manual transmission.Image
Sent from my SM-G930V using Tapatalk
The "Sin Bin"
150133
friz
Postby Ron Dickey » Tue Aug 28, 2018 9:38 pm
any one tried the Prius V???
"Toyota Prius V Towing Capacity, Having a Toyota Prius V maximum towing capacity of 725 kg or 1,598 pounds. The new-gen Prius was designed to tow a trailer or mild, for the very first time in its own 19-year history."
43 city 39 hwy and it holds more then other prius's.
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 707
Postby wriconsult » Mon Jan 13, 2020 6:07 pm
Ron Dickey wrote:any one tried the Prius V???
I think that would be our target vehicle to replace our Mazda5 if we had to. Towing 1598 pounds might be pushing it by US standards (which are VERY ultra-conservative, compared to what similar vehicles are rated to town in Europe) but you could probably do it if you keep the speed down. My goal is a camper under half of this weight, so I'm pretty sure a V would handle it just fine.
wriconsult
Return to Towing and Tow Vehicles
