Do I have a tongue weight problem?
All about towing and tow vehicles
Postby DryHeatDan » Sun Jun 27, 2021 8:45 pm
I have a Koala Bear that is about 1,300 pounds loaded and tow it with a Honda Element which specifies 1,500 lb max towing. The 15% rule of thumb for my Bear says the tongue weight should be about 195 lbs. I tried weighing the tongue on a bathroom scale and it showed 61 lbs over at 256 lbs, or 19.7%. First question - Will using a bathroom scale give me an accurate reading at these weights? The videos I have seen online for figuring tongue weights seem to be for much heavier trailers. Second - is the overage something I need to worry about? Third - if I need to worry about it, any suggestions what to do about it? And, last - should I consider a weight distribution or equalization hitch?
Thanks.
DryHeatDan
Re: Do I have a tongue weight problem?
Postby rjgimp » Sun Jun 27, 2021 10:08 pm
Generally speaking extra tongue weight isn't a problem if your tow vehicle can handle it. Is there a maximum tow weight listed either for your Element or for the hitch you have installed? Does the rear of your Element squat such that the headlights wouldn't properly light the road ahead? I wouldn't be too concerned.
-Rob
rjgimp
Images: 7
Postby Ottsville » Mon Jun 28, 2021 5:37 am
With a 1300 lb trailer and a 1500lb tow rating I would be concerned in general(does your trailer have brakes?). Even more so with a Honda. Don't know which transmission the Element has but my Odyssey had plenty of transmission issues even without towing. There should also be a listing in your owners manual for tongue weight loads and think about what else you are loading in and on your car including passengers. Regarding distribution hitches, keep in mind that those are heavy, possible negating the benefits) and there is some debate if they should be used on unibody vehicles.
Ottsville
Postby QueticoBill » Mon Jun 28, 2021 6:43 am
Mr Google says:
"Per Honda , the max towing capacity for the Element is 1500 LBS, the max tongue weight is 150 LBS, and any trailer over 1000 LBS needs to be equipped with brakes."
Also found this sage post:
"The rated towing capacity has everything to do with liability and is dictated by the insurance folks. The Same exact Element is rated to tow 3236lbs in Australia when using trailer brakes."
I'd certainly not go over the US limits in US because of liability.
So outfit trailer with brakes and figure out how to lighten tongue load. I found moving axel on my trailer not hard, but depends some on fenders. Too much we don't know about your trailer to be able to offer best answer.
Which transmission? 5 speed manual or 4 or 5 speed automatic? Consider a transmission cooler if towing long distances often.
QB
QueticoBill
Images: 22
Postby working on it » Mon Jun 28, 2021 6:58 am
* Estimating the tongue weight with a bathroom scale isn't 100% accurate, but close enough. I looked at the Koala Bear on the Rustic Trail website, and saw that it has a large front storage platform on the tongue...if yours has that, perhaps you could shift an item or two from that area into the trailer, further back, or into your Element. I spent several years moving/adding items forward in mine, to get the desired tongue weight. I started out my first trip with 3% tongue weight.
* 40 lbs/1430 lbs (loaded) was my tongue weight to total weight, since I had planned on having a large box on the tongue, but hadn't yet found one I liked. And, I had already stuffed the "galley" with very heavy items, including a built-in generator and A/C. So, I adapted a weight distributing hitch I already had, to work on my single-beam tongue. Using the wd hitch, I effectively made the tongue weight act like it was much greater, so it was safe to tow.
* Over the years, even after loading the tongue box I found, the tongue weight remained too low (under 10%) for my liking, so I built over-the-tongue box storage racks, and moved items there. Now, I've got 12% (266 lbs tongue weight/2222 lbs total weight), and don't have to depend on the wd hitch anymore (I take it along, in case of bad roads or high cross-winds that might make the trailer unsteady).
173193172890148599
working on it
Images: 457
Postby DryHeatDan » Mon Jun 28, 2021 9:21 am
Thanks for the quick responses. My Element is a five speed manual and the Koala does have brakes. It also has a tongue box and AC at the front, which may be causing some of the problem. I'm going to try moving the side-mounted spare tire to the back of the cabin (under the bed) and see how much that helps. The tongue box has about 50 lbs in it so I can move a few things to bring that down substantially. The E will be about 500 lbs under GVWR, including passengers, gas, some water, and other cooking and foodstuffs.
DryHeatDan
Postby rjgimp » Fri Jul 02, 2021 3:41 pm
rjgimp wrote:Generally speaking extra tongue weight isn't a problem if your tow vehicle can handle it. Is there a maximum tow weight listed either for your Element or for the hitch you have installed? Does the rear of your Element squat such that the headlights wouldn't properly light the road ahead? I wouldn't be too concerned.
Nearly a week later I realize my typing error made my response make far less sense than I had intended. The question I MEANT was whether your Element has a maximum TONGUE weight rating. As long as you are under the gross rating, a tongue weight in the 20% - 40% range doesn't bother me a bit if the tow vehicle can handle it. If you weren't towing but instead had a cargo basket installed in your receiver, would you be comfortable hauling ~300 pounds in it? This is frequently the case with power wheelchairs/mobility scooters which are usually in the 200-300 pound range but heavier duty models often top 400.
You are under the rated limit AND you have brakes, which are really overkill for a trailer under 1500 pounds. A half dozen states don't even require brakes at all unless the trailer is over 4000 pounds. I see no cause for concern. That said, there is absolutely nothing wrong with your plan to redistribute a few things. Though not impossible, it would be difficult for you to accidentally swing things the opposite direction and end up with less than optimal tongue weight which would be far worse.
:vroom:
-Rob
rjgimp
Images: 7
Postby QueticoBill » Fri Jul 02, 2021 4:57 pm
".... have brakes, which are really overkill for a trailer under 1500 pounds. "
Even if the car manufacturer says otherwise? Honda says brakes if towing over 1000 pounds with Element. Subaru says same for my Outback - brakes if towing over 1000 up to its limit if 2900.
QB
QueticoBill
Images: 22
Postby Socal Tom » Fri Jul 02, 2021 5:41 pm
This is good advice. The amount of tongue weight you can handle will be somewhat dependent on the load in the car as well. Too much in the trunks is the same as too much tongue weight. A little extra TW is better than a little less than you need.
Socal Tom
Postby rjgimp » Sat Jul 03, 2021 12:27 am
QueticoBill wrote:".... have brakes, which are really overkill for a trailer under 1500 pounds. "
In the opinion of the vast majority of the US states and Canadian provinces as well as this semi-retired trucker, yes. As you even mentioned earlier, that's determined more by insurance company bean counters than auto manufacturers. The exact same car is rated for more than twice the trailer weight Down Under than here in the States. Also, of those states and provinces that mention weight as a determining factor whether a trailer ought to have brakes, only two as far as I can decipher (New York and North Carolina) require them for a trailer under 1500 pounds. Many states (and I believe one province) don't even mention weight but instead require that a combination be able to stop in a controlled fashion within a certain distance.
My foamie build will likely be well under 2000 pounds and will have surge brakes as the donor frame I am using has them and they work just fine. Getting back to the subject of the thread I am actually aiming for at least 15% tongue weight and would even be comfortable with as much as 25% or so as I just prefer things that way and my main tow vehicle (Hummer H2) can easily handle it.
-Rob
rjgimp
Images: 7
Postby troubleScottie » Sat Jul 03, 2021 4:37 pm
There are some youtube videos which address the concepts of the trailer weight. *towing treadmill demonstration"
https://www.youtube.com/watch?v=JeEEC5eVNCk is nice as is https://www.youtube.com/watch?v=nc0ndz92IWY.
I believe the rule is typically 10-15% ball weight of the trailer. Too much is bad as is too little.
Michael Krolewski
Scottish Terrier Fancier
troubleScottie
Images: 16
Postby cwegga » Sat Jul 03, 2021 5:17 pm
QueticoBill wrote:Also found this sage post:
I would like to point out here that liability is not the only difference between towing in Australia or Europe, etc. and the US. If you look at trailer designs they vary across the world and many places have trailers with more centered axles and correspondingly lower tongue weights per trailer weight. Also going along with that different places have different laws about towing speeds. (Those low tongue weight trailers would be unstable at high US towing speeds) Last time I towed my camp trailer the speed limit at the highest was 85mph (135kph) and I towed at that. Places with different weight ratings, and different trailer designs often have different legal towing speeds also.
cwegga
Postby LeftyDale » Sat Jul 03, 2021 10:54 pm
I would like to second the comment regarding towing speeds. A lower tongue weight can be safe at lower speeds, but unstable at the speeds we tow in the US.
LeftyDale
Postby Ottsville » Mon Jul 05, 2021 7:58 pm
LeftyDale wrote:I would like to second the comment regarding towing speeds. A lower tongue weight can be safe at lower speeds, but unstable at the speeds we tow in the US.
One thing that rarely gets mentioned is these conversations is that in many US states towing speed limit is less than the usual speed limit.
Ottsville
Postby QueticoBill » Tue Jul 06, 2021 5:50 am
https://rvnerds.com/resources/speed-limits-and-towing/
Perhaps I missed one but it seems a total of 5 states still have lower rv limits, and I'm not sure any apply to single axel trailers in the weight range of most tnttt trailers.
QB
QueticoBill
Images: 22
Return to Towing and Tow Vehicles
