Winter in a Generic Benroy
This includes traditional teardrop shapes and styles
Postby TPMcGinty » Wed Nov 14, 2007 8:30 pm
I was wondering if anyone had experience with a Generic Benroy in the winter. I guess my question is does it stay warm inside with only 3/4 inch plywood walls in colder weather? The rest seems pretty well insulated but the side walls are my concern.
Tim
TPMcGinty
Images: 146
Postby Gerdo » Wed Nov 14, 2007 9:12 pm
Mine is built the same way as yours. I have camped in the high 20*s and low 30*s. Rember keep a window open enough to get fresh air. No air = death!
Gerdo
Images: 156
Postby TPMcGinty » Wed Nov 14, 2007 9:55 pm
I would keep a window or vent cracked even though the heater I plan on putting in it will supposedly shut off when the Oxygen level gets to 18%. I was also considering installing a small vent near the heater. I was just wondering because I hope to use it as an ice fishing house too. The temperatures could get in the negative range.
Tim
TPMcGinty
Images: 146
Postby Gerdo » Thu Nov 15, 2007 10:31 am
I don't see any problem if you have a heater and keep it vented. If you have enough heat you could be comfortable in a paper bag. The heater will also help keep the moister down.
Gerdo
Images: 156
Postby AmyH » Thu Nov 15, 2007 11:51 am
I you are concerned about it being warm enough, you could always insulate the walls. That is what I have done. It does eat up a tiny bit of your inside width, but it may be worth it.
Amy
"...follow humbly whereever and to whatever abyss Nature leads, or else you shall learn nothing." T.H. Huxley
Photo Log
Camping Trips with the Tear
AmyH
*The 300 Club
vent the floor if you have room
Postby Guy » Thu Nov 15, 2007 12:52 pm
If you have the room, it is best to vent the floor (or as low as you can go) That way the CO2 can escape and the air enter without heat loss.
Regards,
Guy
Guy
Images: 44
Postby TPMcGinty » Thu Nov 15, 2007 7:32 pm
Thanks Guy for the good advice. Now all I need to do is find a nice looking vent to stick in. Oh by the way I see you are a Marine Corp Fan. That's great! But I'd like to say.....GO NAVY! :)
Tim
TPMcGinty
Images: 146
Return to Traditional Designs
