Teardrop #4 CNC Files
This includes traditional teardrop shapes and styles
Postby tony.latham » Mon Sep 07, 2020 12:36 pm
This cabin is about 125" long but fits on a 10' chasis.
I've developed the CNC files for the internal skeleton, the roof blocking, external skin, and hatch ends. All of the parts are made so they can be cut from 4' x 8' plywood. Both the DXF and SVG formats are available at my webpage at https://www.tonylatham.net/teardrop-cnc-files.html
The DXF files and cutting instructions are attached. Since we're limited to three attachemts, and there are ten files, I'll continue with additional posts.
And for the record: All files are for personal use only. No resale. Copyright © September 2020 Tony H. Latham :thumbdown: (I don't want these showing up on Etsy for $12.)
Skeleton Rear DXF.dxf
(10.31 KiB) Downloaded 358 times
Skeleton Front DXF.dxf
(6.9 KiB) Downloaded 358 times
CNC Teardrop.pdf
Cutting Instructions
(93.28 KiB) Downloaded 381 times
Re: Teardrop #4 CNC Files
Postby tony.latham » Mon Sep 07, 2020 12:39 pm
Continuing along...
Hatch End DXF.dxf
(6.66 KiB) Downloaded 359 times
Ext Skin Rear DXF.dxf
(5.58 KiB) Downloaded 362 times
Ext Skin Front DXF.dxf
(7.79 KiB) Downloaded 373 times
Postby tony.latham » Mon Sep 07, 2020 12:43 pm
I sure wish I had a CNC when I built her.
Holler if you have any questons. :thumbsup:
roof blockng 3 DXF.dxf
(4.44 KiB) Downloaded 356 times
Roof Blockng 2 DXF.dxf
(4.87 KiB) Downloaded 352 times
Roof Blocking 1 DXF.dxf
(4.88 KiB) Downloaded 364 times
Postby tony.latham » Mon Sep 07, 2020 12:48 pm
I almost forgot the galley lip.
Happy camping, happy building, :beer:
Galley Lip DXF.dxf
(6.06 KiB) Downloaded 362 times
Postby aggie79 » Wed Oct 14, 2020 7:23 am
Tony,
That is very nice of you to post the CNC files. :applause: Maybe you could share a little more info on your CNC machine.
Thank you,
Postby tony.latham » Wed Oct 14, 2020 9:56 am
It's called a Lowrider. It's all open-source through https://www.v1engineering.com/. There are two models, the Lowrider which is what I built and the Primo design which is for smaller footprints. I went with the Lowrider since I wanted a full-sheet capable machine.
I had a 4' x 8' bench in the shop so replacing it with this 56" x 111" platform wasn't a big deal. I also use the Lowrider as my assembly bench.
(That video is sped up.)
All of the parts are printed on a 3d printer which takes about a week. You can buy the parts from V1 but I find having a $200 3D printer awful handy.
The firmware is on Github and the part files are on Thingiverse. You can piecemeal the electronics and hardware here and there but I ended up purchasing from V1 since it wasn't going to save much money by scrounging.
Here's a puzzle cube I made that shows what it will do.
That little thing is a serious mind-bender to put back together since there is an inside and outside for each piece.
I wanted to learn how to mill aluminum so I had it cut this router-base plate from 1/4" flat bar.
Here's a sign I made for the local Trout Unlimited chapter:
That was carved in with a V-shaped bit, sprayed black and then run through a planer.
It's handy.
Everything CNC is a learning curve. CAD and CAM and everthing inbetween. I do my 2D –-the CAD-- design using Sketchup and the Gcode --the CAM-- (which tells the machine how deep to cut and a bunch of other stuff) using Estlcam which is fairly easy to learn through Youtube U.
Holler if you want my bench plans.
Postby aggie79 » Wed Oct 14, 2020 3:06 pm
Thank you Tony!
I'm retiring at the end of the year. One of the projects is garage reorganization. Ultimately, I would like to have room for an build a CNC router. I'll check out the info you posted.
Take care,
Return to Traditional Designs
