I have noticed on most trailers that have the air conditioner mounted inside the cabin, they are centered in the cabinet. Is there any reason you can't mount it on one side, closer to the wall?
Scott F.
s4son wrote: Is there any reason you can't mount it on one side, closer to the wall?
Scott F.
madjack wrote:Scott, I believe Mike's L'ill Dinner has it mounted to one side...just keep in mind weight balance and you should have no problems
s4son wrote:madjack wrote:Scott, I believe Mike's L'ill Dinner has it mounted to one side...just keep in mind weight balance and you should have no problems
Jack,
I was thinking of putting the battery in the right-rear. Would that help balance the AC if I put it on the left over the axle?
Scott F.
s4son wrote:I have noticed on most trailers that have the air conditioner mounted inside the cabin, they are centered in the cabinet. Is there any reason you can't mount it on one side, closer to the wall?
Scott F.
arnereil wrote:I've been thinking about the hose hookup... does the cold air come in the top and go out the bottom, or the other way around?
Users browsing this forum: Google [Bot] and 13 guests
