by Jim Edgerly » Sat May 25, 2013 1:25 pm
We've got 3 large overhead plastic bins behind drop down/lift up door, and a large plastic bin underneath a pull out stove shelf. Everything is secured in these bins and even with a rather stiff ride on 50psi ST tires nothing bounces out of place. Can't over rate the plastic bins enough. I bought the bins first, then designed the galley spaces around the bin dimensions.
*When doing anything, if there exists no possibility of failure, then any feeling of success is diminished.
**The glass is neither half full nor half empty...it is simply twice as big as it needs to be.
***If at first you don't succeed, redefine success.
****When I die, I want to die like my grandfather, who died peacefully in his sleep. Not screaming like all the passengers in his car.
