- a side ac unit.jpg (119.26 KiB) Viewed 8233 times
Above the window you can see the a/c is almost flush with the exterior ...
thats the way I want it , on the roof you can see the refrigerator vent - used to suck in the cooling air.
Now for my Crazy idea -------------//---------------
Now for the tricky part.... I want to cut a hole into the side metal upper most wall for a 12" tall x 16" wide 5,000 Btu A/C unit.....
On the exterior the A/C grill will be even with the exterior skin or stick out maybe 1/2" "Like above"
My whole set up will be 100% hidden under the solar panel " can't be seen from the exterior.
The pink is the solar panel cover "with the plastic" still in place to protect the cover.
- a solar panel cover.JPG (88.44 KiB) Viewed 8233 times
On the inside the A/C will stick out into the trailer about 8-9" and will be installed inside a 24" x 30" cabinet.
Here you see the a/c inside a small cabinet - this draws air from the vent on the roof.
- photo 1.PNG (91.91 KiB) Viewed 8233 times
The cooling air will be sucked in from under the trailer with a 4" hose & Bilge blower doing up to 320 CFM
while the A/C is operating the solar panel can be tilted forward - "OUTWARD" on the top 2-3" to allow hot air to escape.
The roof also has a rain gutter - so during rains no water can leak in....
the a/c condensate will run down the trailer exterior wall behind the panel.
During the winter months the a/c can be removed from the cabinet -
when in use I would just open or remove the cabinet door & have full solar a/c.....
I estimate with the supper insulation package full 3" thick R-15+ - that trailer should cool with 2,500 to 3,000 BTU estimated,
last year it worked to 95 deg with 5,000 BTU in full sun on the crappie insulation & metal ribs....OTTCT 1.0
I got this Idea from some RV websites - but they used a large 6" x 24" Refrigerator vent on the roof to supply the unit cooling air
the air was sucked in from the roof & then blown out the side wall- they did not use any blower fans.
Are you following my plan or need more pictures ?
I would like to get your ideas
I wanna keep as much hidden as possible
Thanks Jerry
