what do you use for a teardrop assemble table
What is you assembly table or work bench for you teardrop.
1. What ever I can find.
5
16%
2. a simple folding table or two
2
6%
3. a bench designed and built just for this type of thing
4
13%
4. work benches and plywood
4
13%
5. the back of my truck
2
6%
6. the ground
4
13%
7. another trailer
1
3%
8. my work bench
0
No votes
9. the floor of the trailer I am building, before the sides go up
8
25%
10. see below or see pictures of my table below.
2
6%
Total votes : 32
Postby Ron Dickey » Tue Jun 25, 2013 10:10 pm
Here is one Mike made in 2005 Image
I use what fits and that is saw horses and plywood.
What do you use?
121377......134179
Ron Dickey
Images: 711
Re: what do you use for a teardrop assemble table
Postby planovet » Thu Jun 27, 2013 3:58 pm
I used 2 sawhorses and a piece of plywood reinforced with some 2x4s.
ImageMark (& Cindi)
planovet
The Cat Man
Postby jonw » Thu Jun 27, 2013 5:02 pm
I made a 4x8 platform using 2x4s and a sheet of cheap 3/4 plywood on locking caster wheels so I could roll it in and out as I worked on it.
Worked like a champ :thumbsup:
84795 84807
jonw
Titanium Donating Member
Images: 163
Postby Rlowell » Thu Jun 27, 2013 6:53 pm
I used saw horses and then the trailer base until the walls went up. Then back to the saw horses.
Rod :thinking: :thumbsup:
Plan your work...work your plan...at least that's the plan. Oh, just do it anyway!
gallery/image_page.php?album_id=1425&image_id=76342
Rlowell
Images: 42
Postby asianflava » Thu Jun 27, 2013 7:30 pm
Don't need no stinkin' table. I used the garage floor (and knee pads).
asianflava
Postby Jdw2717 » Thu Jun 27, 2013 8:23 pm
Numbers 2,5,8 and 9 are what I used for mine.
"Twenty years form now you will be more disappointed by the things that you didn't do than by the ones you did. So throw off the bowlines... Explore. Dream. Discover" Mark Twain
John & Tatanya
Jdw2717
Images: 34
Postby RandyG » Thu Jun 27, 2013 9:04 pm
I use an old ammo can in the back and a tool chest in the front. I keep the trailer on that to keep my saw horses handy.
Randy
RandyG
Images: 115
Postby len19070 » Fri Jun 28, 2013 5:33 am
I use what I call "Bingo Tables". I have about 6 of them, 30X96" and I have 2 sets of "Leg extenders" I made to make the table 30", 36" or 42" high.
Depending on what I'm doing. (And how much leaning over bothers my Back)
Happy Trails
Len
len19070
Images: 24
Postby bobhenry » Fri Jun 28, 2013 6:38 am
DUH ! Dummy me, I used the floor of the trailer I was building . :?
Images: 2617
Postby planovet » Fri Jun 28, 2013 6:33 pm
asianflava wrote:Don't need no stinkin' table. I used the garage floor (and knee pads).
I used my garage floor also when my table was not quite big enough :)
ImageMark (& Cindi)
planovet
The Cat Man
Postby Ron Dickey » Sun Jun 30, 2013 11:29 pm
putting plastic on the floor makes sense :thumbsup:
121377......134179
Ron Dickey
Images: 711
Postby asianflava » Mon Jul 01, 2013 12:41 am
I was about to bond the faces to the wall frames with epoxy. The plastic is really slippery when it is doubled up.
asianflava
Postby planovet » Mon Jul 01, 2013 11:08 am
Yep, I was gluing my frame together and did not want to get glue on the floor. Once the glue dried, any that squeezed out peeled away easily from the plastic. ;)
ImageMark (& Cindi)
planovet
The Cat Man
Postby Mary C » Fri Jul 12, 2013 12:25 am
well, this is what I use .....a twenty something picnic table...even as I speak it is in use...
109509
109508
Mary C. :)
Mary C
Images: 473
Return to User Polls
Users browsing this forum: No registered users and 27 guests
