FreeCAD
Want to design your own teardrop or tiny travel trailer. You can do that in 2D or 3D. We keep our secrets in here!
FreeCAD
Postby Fiferguy » Thu Aug 01, 2013 11:26 pm
So my computer is too old to run Google SketchUP, so I downloaded a CAD program called FreeCAD. I've seen other's reference it here, but I can't find the answer to a few questions. Does anyone else use this?
I've gotten the floor and walls plugged in for my trailer, but I can't figure out how to make the skin for the roof, other than creating like a massive block and editing it down. Anyone know any secrets? Maybe a general term for what I'm trying to accomplish in other cad programs that I can try to find?
Thanks!
Fiferguy
Re: FreeCAD
Postby angib » Fri Aug 02, 2013 9:53 am
For something like the whole roof of a teardrop, the options are likely to be:
1) Create a huge 3-D block consisting of the outer surface of the roof, right down to the floor. Create a second huge 3-D block consisting of the inner surface of the roof, right down to the floor. Subtract one form the other to get just the roof. Each of these huge blocks is created from the side profile of the roof (closed along the floor line) extruded sideways by the width of the body.
2) Very similar to (1), create a closed 2-D side profile of the whole outer roof connected front to back along the floor line. Create a second closed 2-D side profile of the inner roof surface. Subtract one from the other to form a closed 2-D curve and then extrude that sideways.
3) Join up the outer side profile and the inner side profile to form a closed 2-D curve and then extrude that sideways.
4) If FreeCAD provides it (probably not) look for a 'shell' command that allows you to take a 3-D zero-thickness surface and then add thickness to it.
angib
5000 Club
5000 Club
Images: 231
Re: FreeCAD
Postby Fiferguy » Fri Aug 02, 2013 9:59 am
angib wrote:For something like the whole roof of a teardrop, the options are likely to be:
Thanks! I had thought about #1, but I wanted another, easier way to do it... ;) The shell command might be the ticket, though. I'll have to research it when I get home to see if it has it or not.
Fiferguy
Re: FreeCAD
Postby Fiferguy » Fri Aug 02, 2013 10:07 am
So it appears that FreeCAD does, in fact, have the shell command. But you have to hard code it in Python, so I guess #1 is my best bet for now considering I know this much: :ok: about programming in Python.
The "Shell" command is exactly what I was looking for though. Thanks!
Fiferguy
Return to CAD secrets
