My first attempt at a lantern box...
Postby Martinjmpr » Tue Sep 24, 2013 8:11 pm
Curious about what you guys think. This is not meant to be "nice", I had just never built a box before and wanted to try out with some inexpensive hardware and cheap 15/32 unsanded plywood I had laying around the garage.
Designed to fit my Sears which is currently the only fully functioning lantern I have:
I haven't seen any other boxes that do this, but it occurred to me that it might be a good idea to put a "brace" or v-shaped notch where the globe rest sits, to keep the back of the fount from rubbing on the back of the box. Should also keep the lantern more firmly in place.
Shelf on top is for mantles, matches, etc.
Is there a way to do the hinges without that ugly gap when it's open? I guess I could put the hinges on the inside of the door instead of the outside?
The sears sits snugly in the box. Tried to use matching (brass) hardware and forest green paint since that's my favorite color. If I do one with nicer wood I'll probably stain it - I like the look of stained wood - and then polyurethane inside and out.
Side view.
So what are your thoughts? I felt a side-opening box would be a nice way to 'display' my lanterns.
Martin and Liz and our new T@B Clamshell "Livia"
Our old Teardrop "bubbles"
Bubbles version 2.0 build thread!
Our Facebook group:
Colorado Teardroppers and Tiny Trailers Camping Group (FB)
States we've visited with Bubbles and Livia: Image
Martinjmpr
Re: My first attempt at a lantern box...
Postby falcon65 » Tue Sep 24, 2013 8:55 pm
Some self adhesive foam weather striping on the v-notch would keep it from beating up the lantern when moving it, one of those clear plastic fishing lure box with all the compartments for keeping spare mantels, gaskets, and matches - lighter, in would be a nice addition to the top shelf. Other than that though it looks like it should work pretty good for ya. :thumbsup:
"There is nothing to fear but fear it's self" FDR
falcon65
Postby ksmack01 » Tue Sep 24, 2013 9:01 pm
Looks nice. Looks like a perfect fit too. :thumbsup: it may be time to trade in my cheesy plastic one.
ksmack01
Images: 61
Postby KCStudly » Tue Sep 24, 2013 9:37 pm
Not bad at all. Has that old timey rustic feel to it.
So, if I have this right, there are three different basic styles of cabinets: Frame-less, which is what you have done has no frame around the box, hinges are hidden on the inside, and the door panels cover the box edges; Face Frame or Inset, where the doors sit inset into a perimeter frame that covers the front edges of the box; and Raised Panel, where the doors overlap (sit proud from) the face frames, but do not cover them. (I'm going from memory here, and despite recent suggestions to the contrary, I am not an expert finish carpenter, so this might not be the exact terminology, but you get the idea.)
If your door is wide enough, you could add a little strip of solid wood to the hinge and latch side, like a face frame, cut the door slightly on each side to inset it, and then screw the hinges and latch to those.
Aside from the risk of bending a hinge plate, or the hasp, I kind of like it the way you made it. It's got that old time purposeful look to it. Old is new again. :thumbsup:
Images: 8119
Postby Zollinger » Wed Sep 25, 2013 7:25 am
I like it! If I remember right Doug has made some in the past that were Birch? And beautiful.
Dawn
Green Lantern Corpswoman
Zollinger
Images: 64
Postby campmaster-k » Wed Sep 25, 2013 9:25 am
Perfect.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby Junkboy999 » Thu Sep 26, 2013 9:36 pm
Nice
Looks like my home made red case.
Junkboy999
Images: 52
Postby campmaster-k » Fri Sep 27, 2013 9:32 am
That dog in the picture is saying " Oh no you didn't just take my picture for the internet!". :lol:
-Kirk
Build thread -
campmaster-k
Postby campmaster-k » Fri Sep 27, 2013 9:37 am
I am going in. I am going to make a box. Results to follow.
-Kirk
Build thread -
campmaster-k
Postby rebapuck » Sat Sep 28, 2013 10:54 am
Look at offset hinges.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby campmaster-k » Sat Sep 28, 2013 12:14 pm
rebapuck wrote:Look at offset hinges.
I was thinking euro hinges, self closing.
-Kirk
Build thread -
campmaster-k
Postby Mukilteo » Sat Sep 28, 2013 12:35 pm
All my wood working tools are at my son's, 300 miles away. :(
Eric
Mukilteo
Postby Sandyman » Sat Sep 28, 2013 8:29 pm
Try using a piano hinge.
Sandy :wine:
Sandyman
Postby slowcowboy » Sun Sep 29, 2013 9:45 am
nice martin. I didn't though rember seeing a sears at walk the winds? did you have it there? slow
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
7000 Club
7000 Club
Images: 166
Postby Martinjmpr » Mon Sep 30, 2013 4:17 pm
slowcowboy wrote:nice martin. I didn't though rember seeing a sears at walk the winds? did you have it there? slow
No, I only owned one lantern then, my non-working 242B. Two days after coming back from Wyoming, Liz picked up a fantastic black-band 200A at the same antique shop and then the weekend of the Trailer Trash Bash in Canon City I picked up the Sears at an antique shop in Canon.
The reason I built the box for the Sears is because it is the only fully functioning lantern I have right now.
Our Facebook group:
Martinjmpr
