How do you skin the inside of a door? (Mine need to be done)
I was going to cover it in 1/2 inch foam, then fake leather. Then install a curtain rod and curtain.
Ant better ideas?
Here is a couple pictures of the inside of my door.
mikeschn wrote:What's the rest of your interior finished with?
Typically I finished the insides of the doors with a few coats of spar urethane.
Yours look a little rough. You might want to knock the edges off with a sanding block, and then coat it with some polyester resin. That'll give it a nice thick, smooth surface.
Return to Essential Information about building teardrops
