I've been working on a simplified version of the vardo pod. The whole intent is to get this thing so simple to build that almost anyone can build one.
Half way through the design it was suggested that I put a bunk in it, kinda like Ed's Sleeping Pod http://tinyhouseblog.com/tiny-house/eds ... s-shelter/
So I added the bunk, but then I had to move the door around to the side. The bunk is 30" wide, and there's about 11" between the bunk and the wall. and the whole thing is still only 4' tall. I'm not sure that this is a practical design, but I'll let you guys look at it anyways.
Here's the pdf. If you click on the picture in the pdf, you can rotate it around, pan it, etc...
http://tnttt.com/images/2013/square%20pod%20version%204.pdf
and if you turn on the tree, you can hide the various panels so you can see the inside stuff.
Have fun! Oh and let me know what you would change!!!
