Slow
I let it soak a little bit with water, sometime heat up the water a little bit and use plastic scraper or scrub brush, it should come right off. You can also use salt as an abrasive. Then re-coat with oil.
Dan.
slowcowboy wrote:what happens after frying that moring egg when the food or the egg sticks to your pan. how do you clean cast iron that has food sticking to it?
slow
