Building the "Heart of Gold" - Done 3/9/2014
Re: Building the "Heart of Gold" - started!
Postby Kullas » Sun Mar 02, 2014 9:51 pm
Heart of Gold the spaceship in the book The Hitchhiker's Guide to the Galaxy
Chris
Kullas
Postby jeporter25 » Tue Mar 04, 2014 10:48 am
Thanks Drew. I was also wondering if you had a gap at the edges of the aluminum on the top or was it a little wider than 5 ft?. I was wondering because your side walls overlap the NT trailer frame and I know that it is 5" wide. I did not see an easy way to make the trailer less wide so I was wondering it the Aluminum is just close enough and the trim takes care of the rest?
jeporter25
Postby drewh1 » Tue Mar 04, 2014 11:12 am
Kullas wrote:Heart of Gold the spaceship in the book The Hitchhiker's Guide to the Galaxy
Yep - you got it! Hitchhikers Guide. I have been mulling over the idea of putting some sort of logo on it.
jeporter25 wrote:Thanks Drew. I was also wondering if you had a gap at the edges of the aluminum on the top or was it a little wider than 5 ft?. I was wondering because your side walls overlap the NT trailer frame and I know that it is 5" wide. I did not see an easy way to make the trailer less wide so I was wondering it the Aluminum is just close enough and the trim takes care of the rest?
The aluminum is exactly 5' wide. My exterior ended up being about 5' 5/8" so I had a small gap. The trim I used is about 7/8" and covered it easily. the 5' x 12' piece easily covered the entire front with some left over for the tongue box. I also used the wide butyl tape that Frank Bear at Vintage Tech sells. I hear you can get it at RV places too. I think it is MUCH easier to deal with than Silicone and seems to spread and seal very well.
drew.
"If only I knew what I know now when I started . . ."
My Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=56916
drewh1
Images: 7
Postby Kullas » Tue Mar 04, 2014 12:00 pm
Its going to look good when its done
Chris
Kullas
Postby drewh1 » Thu Mar 06, 2014 11:57 am
I finished the lid to the tongue box. Not happy with the way it fits, don't think it is going to seal very well. Ah well, I'll redo it later.
added some mood lighting too, way too disco!
drewh1
Images: 7
Postby Woodbutcher » Thu Mar 06, 2014 12:07 pm
Good Job! Looks great. :applause:
Woodbutcher
Postby pchast » Fri Mar 07, 2014 12:01 am
Love the way it came out.
Hope I can do half as well
when the weather breaks.
:thumbsup: :applause: :applause:
pchast
Images: 97
Postby drewh1 » Fri Mar 07, 2014 2:28 pm
Thanks for the complements! I am pretty happy with the way it has turned out and will eventually stop obsessing about all the mistakes and extra holes! I am pretty much done, there are a couple minor things do tidy up but I could drive it off tomorrow and go camping. Hmmm, like others have mentioned, kind of sad to be done in a way . . . (oh, crap, I keep forgetting about the fenders :? )
One thing I have learned from this project and through this forum. I could do alot of things I never thought I could. Just take your time and plan ahead. Take it one task at a time and really think through the steps before you do them. Read the build journals! such a big help. There are some amazing and detailed projects on this site and really good suggestions and information.
If I can do it, I am sure you can too!
drewh1
Images: 7
Postby capnTelescope » Fri Mar 07, 2014 11:39 pm
drewh1 wrote:... and will eventually stop obsessing about all the mistakes and extra holes!
Just tell yourself "The next one won't have those." Works for me. Nice job. :applause: :thumbsup: :applause:
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Postby drewh1 » Sat Mar 08, 2014 8:59 pm
Finishing up some details, here are photos for all you detail fanatics,
Managed to break my hatch support piece so I reinforced it with aluminum . . .
drewh1
Images: 7
Postby drewh1 » Sat Mar 08, 2014 9:01 pm
A few more photos of it done . . .
drewh1
Images: 7
Postby KCStudly » Sun Mar 09, 2014 1:27 pm
It's got a really nice and unique look! The black on aluminum/silver really does it for me. Very elegant and classic hot rod elements to it. :thumbsup:
Re: Building the "Heart of Gold" - done! 3/9/2014
Postby drewh1 » Mon Mar 10, 2014 3:53 pm
Thanks KC - i am going to go with the fenders from Teardroptrailers.net - Black of course!
you can get a pin that fits tight in the holes for the hitch and the noise should go away and make sure the hitch is on the ball tight there might be a adjustment nut under the tounge on trailer tighten it tell it fits good and snug.
I bought one of the locking pins. It fits very snug. Together with a bit more tongue weight, it no longer bangs around and tows easily.
drewh1
Images: 7
Re: Building the "Heart of Gold" - Done 3/9/2014
Postby PKCSPT » Mon Mar 10, 2014 7:11 pm
Really nice
121172 116946 159644
PKCSPT
Images: 61
Postby drewh1 » Wed Mar 12, 2014 10:09 pm
Thanks Karen!
drewh1
Images: 7
