Protecting against interior water damage
Finishes, paints and coatings
Postby Mikesvagen » Sun Mar 30, 2014 1:52 pm
I just purchased a td from a first time builder, he did a great job but I have a couple areas of concern. What would be best to use on the plywood flooring (interior) as a sealant in case there was to be any water intrusion? My concern in is in the event water got in i would not want it to seep into the wood, I want to use something that is safe obviously.
Thanks
Mike
Mikesvagen
Re: Protecting against interior water damage
Postby RandyG » Sun Mar 30, 2014 4:41 pm
I used Killz primer on all interior surfaces.
Randy
RandyG
Images: 115
Postby Mikesvagen » Sun Mar 30, 2014 4:52 pm
Thanks Randy
Mikesvagen
Postby twinight » Sun Mar 30, 2014 11:44 pm
I would think that the primer would hide any damage from water intrusion, not prevent it.
Are you concerned with interior spills or exterior leaks?
Any water that shows up on the inside would have already soaked through the plywood.
I'd focus on sealing every exterior seam and joint.
twinight
Images: 68
Postby bywil45 » Sun Apr 06, 2014 11:56 am
Il faut utiliser un vitrificateur, Avec ce produit, l'eau reste en surface et ne rentre pas. :thumbsup:
Wilhem BENCE
Le france ne connait pas les teardrop, je vais changer la donne en devenant la seul société de fabrication française.
bywil45
Images: 16
Return to Skinning secrets
Users browsing this forum: No registered users and 25 guests
