Was skyline now Mercury, tear inspired camper for six
Re: now look what you did! foamie mouseboat started
Postby Mary C » Sun Apr 06, 2014 2:50 pm
Row, what is the width and length? I have some two inch left over and I was trying to figure out if I had enough to use as the bottom or will I have to use as the sides and you know the drill. I guess i need the sides width (height) and length too. I hope to make it so I can use an electric motor too. I know I will have to put plywood as a transom but I am going to make it portable so it can be added with just a couple of clamps. I have replaced the wood on several boats so I know they rot very quickly. I will in cooperate a piece of cedar on the inside under the canvas as permanent. I do not know boat language and have always just fished from them in private lakes not far from the edge of the pond. I wont be going far from the edge in this one either. Speaking of fish I am going fishing later this week, :twisted: The crappie are running.
Mary C. :lady:
Mary C
Images: 473
Postby rowerwet » Wed Apr 09, 2014 5:48 am
Mary, the boat is roughly 8' long and around 30" wide, I'll get real measurements soon, not really recommended for a motor, but many have used mice with a trolling motor.
rowerwet
Images: 521
Postby rowerwet » Sun Apr 13, 2014 7:45 pm
I made a folder of mouse plans on my FB page, https://www.facebook.com/media/set/?set ... 212&type=3
the originals are on the mouseboats yahoo page, there are also plans for larger boats on the yahoo groups page, Gavin Atkin designs boats for fun and gives the plans out free on the internet.
Gavin also wrote a great book for begining boat builders http://www.amazon.com/Ultrasimple-Boat- ... avin+atkin the plans in it are complete and cover a wider range of boats than just mice.
rowerwet
Images: 521
Postby rowerwet » Sun Apr 13, 2014 7:57 pm
got a bit more done on the boat, started by patching the dents caused by GG tearing out while sanding
118973
finished up taping all the air box inside seams and started on the reinforced cockpit floor
118974
118975
then I decided I wanted strong seams, so I taped the cockpit seams as well
118976
I glued in half the floor, but had to knock off for a cook out.
118977
the cardboard (heavy mating card stock for picture frames) refused to take the curves of the hull and stay down, so screwed it down :hammer:
rowerwet
Images: 521
Postby rowerwet » Sun Apr 13, 2014 8:28 pm
I got a little ahead of myself and did some prep work with the fabric for the bottom
119003
since a flat sheet won't lay flat on a rockered and crowned V bottom I am doing each half and having a good over lap in the middle to add a layer at the point that is the deepest on the hull
119004
I cut darts in the edges to help the fabric lay flat as it curves around the edge
119005
looks almost ready to glue down
119006
I still have to reinforce the cockpit edges and want to cover the sides so the bottom overlaps them so these bottom panel fabrics will be sitting until about last. Gonna be interesting to see what the final weight will be, unless the glue drying makes the boat lighter I am finding the weight gain is to the point I'm not sure I could stand it on one finger again...
rowerwet
Images: 521
Postby rowerwet » Mon Apr 14, 2014 8:14 pm
hit 70 degrees for the first time this year today, took the boats out for a paddle, my son wanted to know why the new boat wasn't going. Uh... if only, but I'm gonna wait and finish it before launching it.
I did finish the cardboard floor for the cockpit today...
rowerwet
Images: 521
Postby rowerwet » Wed Apr 30, 2014 4:56 am
got a bit more done119643119645119648
rowerwet
Images: 521
Postby GPW » Wed Apr 30, 2014 6:48 am
It may end up a two-finger boat ... 8)
Postby rowerwet » Wed Apr 30, 2014 8:14 am
until I put the TBII, fabric and paint on it I think it will be equal to my light weight plywood builds. 30-40 lbs
rowerwet
Images: 521
Postby GPW » Wed Apr 30, 2014 8:30 am
Actually that’s still pretty Light , and it FLOATS ... 8)
Postby rowerwet » Fri May 09, 2014 4:53 am
after the rail reinforcement strips glue dried I sanded the extra glue off and rounded the edges over with the router, 120001
glued the decks on with GS
120002
and sanded the "beard" of extra GS off,
120003
now I'm ready to put the fabric on!
120004
can't wait to splash this puppy! er... mouse!
120005
rowerwet
Images: 521
Postby GPW » Fri May 09, 2014 4:58 am
:thumbsup: 8) No Punt intended !!! :lol:
Postby bonnie » Fri May 09, 2014 6:15 am
Looks great. I am really interested in how much it weighs went complete. :)
Remember, the turtle won. :)
bonnie
Images: 107
Postby GPW » Fri May 09, 2014 6:43 am
Just thinking , a judicious application of common fiberglass drywall tape would reinforce areas under the skin, with little weight gain ... Put the glue on the foam, add the tape , cover with the fabric... Simple ... Thrifty too... Just a little added “insurance” ... :thinking:
Postby rowerwet » Fri May 09, 2014 11:35 am
I have considered some fiberglass tape to give extra protection to the keel, however I don't see much strength in drywall fiberglass tape, but I have plenty of 2" fiberglass tape from my ply boat building.
I'm wondering if foam will stand up to my kind of use, while the designer says this boat is only for protected flat water, I've done white water and ocean surf with some of my other mice.
rowerwet
Images: 521
