48Rob wrote:
Some mattresses are 4" thick, some 8", some more.
Knowing all the measurements makes cabinet and door placements much easier, and in the end, more comfortable to use.
The thickness you choose should be based on the desired comfort level, the amount of weight your design will accept, the door opening height from the floor, and how much clearance you want/need between the mattress and cabinets,
Rob
PaulC wrote: It is almost as comfortable as our bed at home.
Kurt (Indiana) wrote:PaulC wrote: It is almost as comfortable as our bed at home.
Paul, I find that I usually sleep better in the teardrop than at home. Maybe the food and beverage menu is a little better on teardrop time.
PaulC wrote:Maybe it is the "lifestyle" when Teardropping.
Cheers
Paul
Users browsing this forum: No registered users and 43 guests
