Gas struts
Gas struts
Postby rooster » Fri May 19, 2006 1:47 am
Danny mentioned that he use 120# gas struts for his hatch, one on each side of the hatch. Does that mean it will push up 120 pounds, or is there a formula that is used?
Jim, :?
Beware of what she wishes....especially with that twinkle in her eye and that mischievious smile....you know it's gonna cost....
rooster
Images: 42
Postby emiller » Fri May 19, 2006 6:50 am
8)
Here you go Rooster click on this link http://www.mcmaster.com/ and type gas struts in the search box.
emiller
Images: 157
Re: Gas struts
Postby halfdome, Danny » Fri May 19, 2006 9:24 am
rooster wrote:Danny mentioned that he use 120# gas struts for his hatch, one on each side of the hatch. Does that mean it will push up 120 pounds, or is there a formula that is used?
Jim, :?
Jim, I wondered the same and came to the conclusion that if there is enough support for that strong of a gas strut it's the easiest way to guess. I have 3" Popular framing on the galley walls so I went for the 120 pounders. When I open the hatch some of the weight is assisted by the struts and it increases as I lift it until I get to about 3/4 of the way open. The struts then really do their work and lift & hold it up very well. I noticed while closing that I'm only compressing the struts about 3/4 + of their capacity when the hatch is shut. 8) Danny
halfdome, Danny
*Happy Camper
Images: 188
Gas Struts
Postby rooster » Fri May 19, 2006 8:11 pm
Thanks for the information. . . . :thumbsup: :applause:
Jim
rooster
Images: 42
