Now onto a simple hard point.
So you have a place that you need a hard point for attaching something in foam. Well you could use wood, or you could use this simple method.
You will need a soldering gun for this procedure. I have a actual gun, but I believe a soldering tool would work if it had a long enough point.
I will be using a scrap piece of foam and flashing for this example.
First make a piece of flashing the size you need it. In this case I used a piece of scrap about 6" long. Now place the flashing where you need it upside down with the angle away from the cutting edge.
- Hard point
- DSCF3376 s.jpg (90.18 KiB) Viewed 2858 times
Next, take the soldering gun and get the tip hot. Use the flashing as a straight line guide for your soldering gun tip and make a straight slot. Make sure you go down deep enough for the angle to fit.
- Cutting a slot
- DSCF3377 s.jpg (86.95 KiB) Viewed 2858 times
Now flip the angle over and install into the slot you just made to make sure it fits. Now all you need to do is glue it into place with GG, GS or Gripper. I think I would use GS in the slot and Gripper between the wall and the angle so I would not get any lifting form the GS. This should hold most light items or hinges.
