Insulation?
Insulation?
Postby Diemjoe » Wed Jan 14, 2015 9:23 pm
I have seen that Teardrop builds universally use some sort of solid styrofoam for their insulation. Why is that. I have some rolls of insulation cluttering up the attic and garage and was wondering why I couldn't use that.
Don Miller
Seattle
Trippinwithdon.com
Diemjoe
Re: Insulation?
Postby rowerwet » Wed Jan 14, 2015 9:35 pm
Fiberglass batts are designed for thicker walls than an average tear will have. 2x4 with the 4" being the thickness of the wall, meaning you loose 8" in width to wall thickness.
Foam board will do as good of a job in a 1" to 2" thickness wall.
Fiberglass batts make a great home for mice and bugs, they also will soak up water, hold it, and rot your wall out.
rowerwet
Images: 521
Re: Insulation?
Postby Diemjoe » Wed Jan 14, 2015 9:54 pm
Thanks, I thought it would be a water thing but hadn't considered the wall thickness part of the equation.
Don Miller
Seattle
Trippinwithdon.com
Diemjoe
Re: Insulation?
Postby backstrap bandit » Wed Jan 14, 2015 10:03 pm
Also batted insulation will not stay in place too much jarring while driving it would end up settling in to bottom of wall
backstrap bandit
Images: 15
Re: Insulation?
Postby grant whipp » Thu Jan 15, 2015 1:18 am
I've used fiberglass batt insulation in the ceilings and hatches of my teardrops for years and never had a problem ... I use the foamboard for the walls, though ... ;) ...!
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
Re: Insulation?
Postby mrsteve » Fri Jan 16, 2015 12:02 pm
When you compress the fiberglass insulation thin enough to fit inside the teardrop wall you will lose most of the "R" value. Insulation needs "dead" airspace to work, smashing it flat takes the dead airspace away. Styrofoam uses closed cells to insulate.
mrsteve
Re: Insulation?
Postby grant whipp » Fri Jan 16, 2015 12:15 pm
Yes, when you DO use fiberglass insulation in your roof and hatch, you should split it down to fit the thickness of each ... however, you can find fiberglass Water Heater Blankets that are real close to 1-1/2", and they work great as is (that's what I've used in my hatches for years ... ;) ...)! As always ...
CHEERS!
grant whipp
Images: 117
Re: Insulation?
Postby Diemjoe » Fri Jan 16, 2015 1:08 pm
Beyond the extra insulation rolls I have lying around the house, the other reason I asked the original question is the mess that I think sanding down the styrofoam to proper thickness will create. Its got to be worse than getting glitter bombed.
Don Miller
Seattle
Trippinwithdon.com
Diemjoe
Re: Insulation?
Postby felixx » Fri Jan 16, 2015 2:11 pm
Im guessing this is where a hot knife will work
Sheddie made a nice one
or have a look on any RC plane forum.
The one I use for planes is made of Nichrome wire with a battery charger (12V) attached
felixx
Images: 22
Re: Insulation?
Postby Diemjoe » Fri Jan 16, 2015 2:22 pm
Thanks Felixx, I will look into that.
Don Miller
Seattle
Trippinwithdon.com
Diemjoe
Re: Insulation?
Postby bobhenry » Fri Jan 16, 2015 2:58 pm
I insulated Chubby , the barn, Rip Van Winkle, The caboose, and the house in the house all with blue foam. I pre cut them on the table saw with little mess and the odd duck sized cavities were cut with a sharp handy knife and a straight edge.
Images: 2617
Users browsing this forum: No registered users and 50 guests
