Yes, getting the trailer is turning out to be an adventure. But luckily I got a really good deal.
I revised the camper blueprint and want to see what you think. Please suggest improvements.
The floor, wall and ceiling skeletons will be built out of 1x3's and 1x2's. This will provide significant weight savings and 3/4 inches of interior space for foam insulation. The skeletons will support a sandwich of plywood on both sides, that will be glued in place. The interior floor and exterior roof will be 1/2 inch ply for strength, with 3/8 inch ply for the interior ceiling. The walls will have 1/4 inch ply on the outside and 3/8 inch ply on the inside. The camper box will be wide enough for a 60 inch width queen mattress on the inside, plus 2 inches to spare on each side. The length is 96 inches at the floor and 75 inches at the ceiling.
(Only floor and ceiling 1/2 inch plywood is shown; wall plywood is invisible in this view.)
Specific questions:
1. Should there be a bottom ply to the floor, or will the metal trailer floor suffice?
2. Is 1/2 inch ply a good width for the floor and roof? Does it need to be thicker or not? I would like to use the trailer for cargo also, and the roof may support a solar panel.
3. I use triangular pieces of wood in some corners for stability. Will that be enough?
Thanks!
Lauren
