I received the replacement handle in the mail the other day but have a while before they get installed. I have been making some good progress the past couple of weeks.
I thought that having a Bumper on the trailer would be a good idea. Easier to weld a frame rather than rebuild the cabin in case of a minor rear end collision. I got the idea for a removable bumper so that it wouldn't be in the way when using the galley.
- NA US WA Seattle -Frame Bumper - IMG001.jpg (117.09 KiB) Viewed 1632 times
The wheels are tack welded onto the frame. Since I am still not sure where they will finally be placed, I decided to move ahead with less skeletonizing around the lower back sections of the wall so I make sure I have something to screw the fenders into when the time comes. Speaking of Fenders, I bought a couple so I could get a feel for length and width. I think my axle might be a bit wide because the distance from the outside wall to the outside tire edge is about 4 inches wider than my fender. I think I'll just return these and build my own fenders. It doesn't look like a big undertaking.
I attached the inside skins using construction adhesive. I should have spreads it out better before I laid on the skin but it was setting up pretty quickly. I will put that in the nice to do category since the skins don't look rippled or anything. I am a little disappointed in that spots and streaks of the floor undercoating have gotten on the skins from having to store them in the same place I am building the trailer. That stuff doesn't sand out very well, especially on that thin plywood. I should have waited to buy the skins until I needed them.
I am using a version of Frederick method (Dado Joint) for joining the walls to the floor. I sliced of the bottom two inches of the wall (including the floor height), glued and trimmed the inside skins, Stained all sides of the trimmed off bottom of the walls and glued and screwed them to the floor. Finally, glueing and Kreg Screwing the walls to the floor. Seems pretty solid.
- NA US WA Seattle - teardrop Cabin Walls - IMG001.jpg (93.57 KiB) Viewed 1632 times
While I was doing one final check of the wall dimensions to the floor, I noticed that the bottoms of the wall were 1/2 inch shorter than the floor. I have no idea how that happened but luckily it was easily solved by trimming the extra length off the floor.
- NA US WA Seattle - teardrop Cabin Walls - IMG002.jpg (85.79 KiB) Viewed 1632 times
