I put steel wheels and snows on my subaru and a piece of black electrical tape over the sensor light. I use a tire gauge and a calibrated eyeball (50+ years of checking tires). Seems to work just fine.
Loren
Woodbutcher wrote:My light has been on in my van for 2 years. I'm not fixing it. I have driven for 40 years before getting a vehicle with a low pressure warning light. I plan on making is till my kid takes my keys away before worrying about it. But that's just me....
Are we getting scammed by these guys telling us they have to be replaced every time we buy new tires?
Catherine+twins wrote:When ever I get new tires I get hit $40 each for new sensors. My dear step-dad, too. Are we getting scammed by these guys telling us they have to be replaced every time we buy new tires? Never occurred to me to argue.
At the same time, I had one not sealing from day one (bought some fix-a-flat, gunked it up good, it's fine--hey, the local garage guy told me to), and another go bad within two months of buying new tires. Every cold morning (hey, winter???) it shows low pressure (not). Just as well we only had winter for two weeks this year.
Catherine
Tony, we have an '06 Tacoma. Last winter the sensor system began to give false low pressure warnings when the temperature fell to below freezing. That was an early signal that at least one battery was failing.
Padilen wrote:MtnDon,
I'm against legislation when it should be common sense. Seriously people need a law to tell them not to text and drive?
Catherine
Lesbest wrote:Since the TPMS system is federally mandated, any removal or modification is against the law. The early Corvette system had location specific sensors. A used wheel with a LF sensor on the RF would make the module go crazy---2 LF sensors and no RF sensor, you had to look for the problem. The new cars have smarter sensors that are programmable, after they are installed , the tech goes from wheel to wheel in a prescribed order to teach the sensor where they are. Since cars only have 4 wheels, and a spare the module will only read 5 inputs and a trailer wheel would be too far away for the module to read it. A tech walking thru the lot with the reader/programmer in his hand can by turning it on and going thru the wake-up sequence change the sensor on a car he is walking passed by accident. Don't know it happened till owner comes back with a stupid sensor (light on) and it reprograms ok.
The sensors are not universal, they can be car specific, wheel specific, and year specific. PA. has an inspection yearly to get your plate sticker and the light has to be off to start the inspection, thus you have to maintain the system.
Fix-a-flat will kill a TPMS sensor, if you have a slow leak get the tire fixed. If you used fix-a-flat the chemical in the slop gets in the hole in the tire and stops the leak, but the chemicals are not compatible with the glue for patching, so that means you ruined the tire too, because you can't patch it.
Look at the box or bag the sensor comes in, it's dated, New Old Stock, or NOS is not good for TPMS sensors, 6 years old when installed won't give you 5 years use. So watch buying online auctions.
You can thank the legislators for these added items, the manufacturers HAD to add them, helped along by the Ford Explorer debacle, from a few years ago.
Hope this helps,
Les
Hope this helps,
Les
