Single burner propane stoves?
Postby wa_flyfisher » Tue May 30, 2006 5:42 pm
This is the stove that we use when camping.
http://cspoutdoors.stores.yahoo.net/porbutbur.html
wa_flyfisher
Postby BrwBier » Tue May 30, 2006 9:26 pm
I just don't know about those butane stoves. Hank Hill says "butane is a basterd gas"
BrwBier
Images: 100
Postby Ira » Wed May 31, 2006 7:24 am
One-hitters, whippets and stoves--what a connection!
Remember that little device they had for the whippets--it was like a small canister, put the balloon on one end, twist to puncture, and the balloon fills? Are we all going to hell for remembering this?
And am I specifically going to hell because I worked at a supermarket while in high school in the dairy department, BEFORE Redi-Whip started using tamper-proof tops? Yes, there was an inordinate amount of returns of Redi-Whips during my tenure with that food emporium.
But for stoves to use in in the galley, I'm probably gonna go with propane. I just want two little burners that I can throw in the storage area and pull out when needed, and not take up a lot of counter space. Those propane units look nice, though.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Miriam C. » Wed May 31, 2006 11:11 am
Ira,
I have a butane stove and it is great. Has a case and sits under my van seat along with a steel pan and stuff. The kids use it when the fish are biting and the adults forget to feed them. 8)
I will probably switch to propane for the tear because I think the fuel can is less likely to puncture, or just get too hot.
Miriam
Here's one Ira -
Postby Nobody » Wed May 31, 2006 7:18 pm
I've had this thing longer'n I care to remember, way more'n 30 years. It was mfg'd by Primus & is called the 'Grasshopper", presumably 'cause of the spindly legs. It was designed to use the longer 14.5oz cylinders but works well with the shorter 16oz too if you use some kind of block to raise the bottom of the 16oz cylinder by around 3/4". The control valve is incorporated into the cylinder connector & is operated by just turning the valve/cylinder. The utensil resting surface is rather small but I've cooked lots of bacon 'n eggs in a 9" skillet. The grates/pan rests fold inward for storage. The entire stove can be carried in a small pouch about 3" in diameter by 12" long. Not sure they're even still made but I've seen similar in outdoors/camping gear catalogs. Additional pix are in my album.
Harvey -
Nobody
Images: 342
Single burner Coleman Powerpack Stove.
Postby goramsey » Sat Apr 03, 2010 6:39 pm
I just bought the Coleman Powerpack Stove. 1 large burner. Just what I have been looking for. I had a Coleman 2 burner stove that I used for 30 years. I could only cook with one 10 inch pan. That sucked. With this puppy, a large pan is no problem. If I like it I will add a second to my collection. I will let you know.
I tried to post a photo of the unit in this post. All I got was a photo and I was unable to add any text. What am I doing wrong.
FACEBOOK: http://www.facebook.com/pages/Ramseys-T ... 4019963253
Hunger makes a thief of any man. ~Pearl S. Buck
Food is an important part of a balanced diet.
Fran Lebowitz
http://www.ramseystravels.com/blog/
goramsey
Images: 97
Coleman single burner stove
Postby goramsey » Sun Apr 04, 2010 5:58 pm
Here is the stove I just purchased.
Fran Lebowitz
goramsey
Images: 97
Re: Coleman single burner stove
Postby Classic Finn » Sun Apr 04, 2010 6:06 pm
goramsey wrote:Here is the stove I just purchased.
Nice stove. ;) Only one thing, here that gas (jug) is too darn close for comfort. Here it must be 1 meter or 3 feet away with a special shut off valve in between. :?
Wonder whatever happened to Ol Ira ? You brought back memories of a hilarious character :lol: :lol:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby goramsey » Sun Apr 04, 2010 6:42 pm
That is no problem, just get a hose adapter, and get rid of that little metal thing.
Fran Lebowitz
goramsey
Images: 97
Postby goramsey » Sun Apr 04, 2010 7:33 pm
Here is the stove in the kitchen with a cool rubber surface to put it on. The stove doesn't move around that way.
Fran Lebowitz
goramsey
Images: 97
Postby doris s. » Sun Apr 04, 2010 7:34 pm
We have a Coleman fold and go stove. Works great and compact for a two burner stove.
http://www.coleman.com/coleman/colemanc ... oryid=2010
Doris
doris s.
Images: 32
Postby Dale M. » Sun Apr 04, 2010 9:02 pm
Actually I have a.........
Coleman Speedmaster, Model 500 stove. From post WW II era...
Dale
Dale M.
Images: 18
