bc555af wrote:Thanks for the link! Looks like he had little effort with what looks to be a Clubman. Tomorrow morning I will start the installation of the hitch and wiring. The wiring is done exclusively in the tail light access doors in the boot. To get power, you have to tap into the 12V outlet also located in the boot which is great because I was scared to run wiring all the way to the battery. We shall see! I will post pictures of the installation.
Hi S&S
I touched on this in an earlier post however did not mention the stiff suspension, the TD drops the back end only slightly. The Mini towed "Dewey" through the Smokeys with little effort, revs were never above 4000 in 3rd on fairly steep 2 lane blacktop, so far so good. We did not anticipate mid 80 degree temps in Florida, we had 2/50 air on (open 2 windows and drive 50 mph) to keep aluminum block cool.
