KCStudly wrote:Assuming that you don't want to raise your floor and galley counter height too much, I'm with Sheddie on this one. A 1 inch longer shackle will add about 1/2 inch more lift.
Beyond that, you could change how the fenders are mounted. Instead of bolting/screwing them to the side wall, you could have fender brackets welded on to the under side of the frame that extend out to the lower leading and trailing edges of the fenders.
Users browsing this forum: No registered users and 66 guests
