Door Trim (T-Molding)
Postby Bandit » Wed May 31, 2006 4:30 pm
Who sells T-Molding that will bend around the radius (easily) of my doors?
I am going to finish the door frame using bondo and paint, so the door opening will not require a molding. I only want to use the molding for the doors themselves.
Thanks!
:thumbsup: :thumbsup: :thumbsup:
First Metal Cut 02/11/06
Complete! (Almost) 08/22/06
Looking for a trip in the SPRING!!!!
Not Up to Testing the Heater!!!
Thanks for all the HELP!!!!
Bandit
Postby asianflava » Wed May 31, 2006 4:37 pm
Whew, that is pretty tight. What you may have to do is anneal a piece and bend it, then anneal it again and bend it some more. I played with different thicknesses and found 1/8 to work out OK, the thinner pieces would buckle.
But like I said, that radius looks pretty tight so I don't know if it would work.
asianflava
Postby Bandit » Thu Jun 01, 2006 2:46 pm
To get your attention, I am posting this back to the top of the list!
Come on guys and gals!
Where can I get T-Molding for my doors.
I know at least one person has done this.
I'm practicing with annealing, I'm afraid soft would be susceptible to bending on the edge of my doors.
:lol: :lol: :lol: :lol:
Bandit
Postby rainjer » Thu Jun 01, 2006 3:12 pm
asianflava wrote:Whew, that is pretty tight. What you may have to do is anneal a piece and bend it, then anneal it again and bend it some more. I played with different thicknesses and found 1/8 to work out OK, the thinner pieces would buckle.
I would have to agree. I do not see it possible to bend that radius even annealing it. I don't even think you could do it with a shrinker-stretcher. In order to bend that tight of a radius the metal need somewhere to go. You would need ti V-notch the inside side of the "T".
As far as where to get it, I am getting mine at a carpet store. I is soft enough to bend, but not that much.
rainjer
King Koleman
Images: 11
Postby Bandit » Thu Jun 01, 2006 3:38 pm
I do plan to notch the inside radius.
What do they use this for in a carpet store?
Thanks!
:thinking: :thinking: :thinking:
Bandit
Postby rainjer » Thu Jun 01, 2006 3:44 pm
Bandit wrote:I do plan to notch the inside radius.
Thanks!
They call it hatch metal.
This is the one I used.
http://www.tacometals.com/prod-level6.asp?c=3&StartPage=Home&rootN=A50-0305&sID=1&ssID=124
I beleive Taco Metals sells direct.
rainjer
King Koleman
Images: 11
Postby madjack » Thu Jun 01, 2006 5:09 pm
Bandit, as the Rain man said, it should be available thru a flooring store and is called hatch trim or trap door trim...and like the others, it would be hard to amke that bend without cutting the metal either with a notch or radiusing inside section of the "T"...the outside section should strech enough on its own...we did some angle in a 2" radius and as long as it was the outside leg it would strech enough...most of the TD supply houses sell a deadsoft "T" molding (Lil Bear, Teardrop Fix-it, SoCal td's etc)
madjack 8)
Postby Bandit » Thu Jun 01, 2006 9:13 pm
I did some testing this evening with annealing and kerfing. I used a small torch that uses MAPP gas and Oxygen, sooted with a standard candle and it took less than a minute to anneal about a foot of the aluminum. All the soot burned off.
I then tried kerfing it and found that I need to kerf it before I anneal it. When I kerf after annealing, the small tabs are so soft that they bend down with the scroll saw blade. Tried kerfing before annealing and it worked much better.
Bandit
Postby Ira » Fri Jun 02, 2006 8:47 am
Everyone I've heard from says that Grant's stuff is great to bend, so I'm gonna go with that.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Rickxr2 » Fri Jun 02, 2006 7:35 pm
I got my t-mold from http://socalteardrops.com/ Bent very easily with no annealing, no kerfing. Not quite as tight a radius as you have though.
Rick
Image Image Image
Rickxr2
Images: 125
Postby Bandit » Sat Jun 03, 2006 9:04 am
Rickxr2,
Where did you get the drip rail?
I could add some radius to my doors, but it would require adding a filler and a lot of finish smoothing work to make it un-noticeable.
Bandit
Postby Joanne » Sat Jun 03, 2006 10:38 am
Bandit wrote:Rickxr2,
My trailer is grasshopper/weekender/or whatever you want to call it. I have gone with square corners and they don't look bad since the rest of the trailer is angular (like yours). No bending the trim. Just a thought.
Joanne
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
Postby Rickxr2 » Sat Jun 03, 2006 2:50 pm
Bandit,
I got the drip rail from Mobile Mart. I'm not sure if they sell it from the internet, I picked it up from their retail store in Tulsa.
www.mobile-mart.com
Rick
Image Image Image
Rickxr2
Images: 125
Postby Bandit » Sun Jun 04, 2006 9:18 am
I kerfed the aluminum and then annealed it and it is working quite nicely. I'll post some pics later.
Bandit
Postby rmcelroy » Sun Jun 04, 2006 9:36 am
Rainjer, the T you used looks like it has a ridge cut halfway down the leg. Could the leg be broken off at that point? Long story short I need a T with a 3/8 or 1/4 leg.
Mc
Wheather you think you can or you think you can't, your right.
Henry Ford
rmcelroy
Images: 27
