After floor insulation was finished we covered it with 1/2" Advantec sheathing. I chose Advantec for it's weather resistance and the likelyhood that it would get rained on during construction. Several years ago I built our current "big" home and had used osb subfloor. We got a LOT of rain that year and I ended up having to sand the swollen seams before adding finish flooring. I vowed to do it differently the next time.
I chose 1/2" because headroom is so limited with DOT height requirements and every fraction of an inch adds up. Well, it kind of worked out and kind of didn't. 1/2" is not enough over 24" floor joist spacing. Even with bays full of foam, it flexes. Also we had a very wet June and the seams swelled. I will cover the interior space with 1/4" plywood after sanding the seams and this will fix the two issues plus give me a fresh surface to put finish flooring over. If I do it again I would still pay extra for the Advantec but go thicker.
This is already a long post but I've shared framing pics below, so I'll just mention that I used 2x4s for framing walls at 2' on center. I also skipped "jack studs" for the openings to lighten final weight and increase the amount of insulation. With the short wall height, I also used the double top plate as the header. I think with such a small structure, the use of plywood sheathing, and the added streignth of foam in the walls, that it will be just fine.
That's enough for now. More to follow.
- uploadfromtaptalk1436704932334.jpg (217.73 KiB) Viewed 5312 times
- uploadfromtaptalk1436704921562.jpg (229.94 KiB) Viewed 5312 times
