daveesl77 wrote:The semi-clear stuff that is on the HF hubs is not "grease", but is a packing compound. In multiple areas of the instructions you will find that you must repack the bearings. I'm old school and hand repack all bearings on every vehicle I have. I also do it every 3-6000 miles. I prefer the red grease, but any good axle grease will work. Fully filling the interior of the hub is actually a bad idea as it tends to retain heat at a much greater level. I know a bit about doing stuff like this, as Jr. Johnson taught me as a teenager on how to build race cars.
dave
Werdahekrwe wrote:I got it home and found out the new ones have a 5 (YES F I V E) lug pattern AND a grease fitting in the spindles.
