Today I managed to get the rear screened window framed. Then a roll down shade was installed. It uses a crank to roll it up and down. You can see the crank on the right. Yesterday my sister came over and put the last coat of paint on that rear wall.
I then installed the TV. As you can see below the tv gets in local channels using the antenna I assembled that you saw in a previous post. The TV is a 22 inch NAXA.... I know, a weird brand, but there aren’t many that run on 12 volts. The TV is mounted above the foot of the bed. It’s connected to a jack on the wall to the antenna and to the Sardine sound system that I had ordered earlier. The sound device sits on the counter and plugs into the wall.
Also connected to the TV is a USB and SD card movie player. I can load dozens of movies onto a thumb drive and this little device will play it
through the TV.
Everything needed has been installed in the wall, cable tv connection, Audio jacks, USB and 12 volt power sources, Video playing device.
The device comes up with a menu to play a variety of different things. I’ve got about 30 movies loaded onto the little thumb drive you see hanging from the blue video device.
The Sardine sound system connects to the wall jacks and picks up sound from the TV. It is also a radio and bluetooth sound device.
I also mounted the indoor/outdoor temperature, clock to the wall.
Tomorrow will be time to haul the mattress out and make the bed up. It’s the memory foam mattress from the old teardrop we had. Then I’ll make it up with a surprise. My neice delivered a gorgeous hand made quilt she recently finished for us.
- Entertainment system plays over the air TV, cable when available, DVD, and video files from a thumb drive. All 12 volts.
- IMG_0861.jpg (31.74 KiB) Viewed 4792 times
- Clock, indoor/outdoor thermometer.
- IMG_0871.jpg (29.96 KiB) Viewed 4792 times
Conform and be dull.
