by smeerkees » Sun Jul 07, 2019 6:56 am
Ok,
first of all i show you a picture of my trusty ringroller.
You need a good ringroller for this type of job.
Rolling a part of a circle is not that difficult.
With a ringroller you bend your material a very little bit at a time when rolling at through the machine.
( Edit) The material i use for the ribs in this build is 25mm x 25 mm x 2 mm wallthickness. square tubing.
When you need to bend multiple pieces of square tube the same bend (radius) i would recommend to bend your pieces at the same time.
So bend all your pieces before tightening the bender for the next round of rolling.
You will see that all of your pieces will be remarkable the same.
However when your material is from differend batches from the manufacturer there can bee some minor differrences.
Now for bending part of eliptical bends is a complete differend story.
First of all be sure that your material is from the same batch of the factory. (minor differences in your material for instance wallthicknes or little temerature differences in the manufacturing proces can give small differences in bending results. Oh and i made sure that the welded side of the square tube was Always on the same side for the same reson and result. Personally i used the welded side always on the inside of the bends.
For this job you really need to bend your pieces of material at the same time each time.
Then scribe the exact place on all of your work pieces by stacking up the tubes and scribe your measurements, and tighten the ringroller for the next round. Each time a little bit of smaller radius.
Rolling one piece of tube at a later time and exactly the same as the other ones in an elypthoid radius with a hand ringroller is very difficult, and close to impossible.
Especcially when your radius spec. on for instance a 4 ft. long eliptical piece of bend is less than 1\ 20 of an inch. Everywhere on the complete radius bend.
Why so tight on specs, well when you want to use aluminum plate as skin for your teardrop trailer the slightest difference in radius of your bended ribs is noticeable in the end result.
So you have to get used to work with your rolbender. and know some basic rules.
For instance when you bend 2 pieces of square tube. 1 piece you tighten your rollbender 1\2 turn, and the other 2x 1\4 turns, your end results are not the same. Sounds strange,
but by every (partial) turn you make on the rolbender your material has a little bit of elastical bending before plastical reforming your material.
So when you tighten your ringbender 1\2 turn and roll your material through the bender, the end result will be a little bit differend then when you tighten your bender 1\4 turn, roll your material, and then turn your rollbender 1\4 turn tighter again and roll your material again.
So the bends on the back part of the teardroptrailer as in my pictures are way more difficult to make than the front radius.
Also when u use a ringbender or rollbender,, your square tube material will not be exactly square anymore. Yes the bends are beautiful, but remember that the rest of the excess material has to go somewhere. I quess that when i would make a ridge in the middle of the benderwheel in the middle the tubes would be more square in the end, but at the cost of having a big ridge inwards on the insides of the bends. And that would be more difficult fitting for welding wize. So there is Always a trade off.
I guess you had no idea if i didn`t tell you.
- Attachments
- IMG_1968 verkleind voor tnttt.JPG (38.95 KiB) Viewed 3207 times
- IMG_1904 verkleind voor tnttt.JPG (44.7 KiB) Viewed 3207 times
smeerkees on Sun Jul 14, 2019 3:27 pm, edited 6 times in total.
