Atomic, would you have any concern with me just laying the cloth down and squeegeeing straight thru? If delamination with the foam/spackle is that big of a concern (not building an airplane, really not) I suppose I could bore a series of “post holes” thru the foam down to the top of the ceiling/hatch inner skins and fill those with thickened epoxy before laying out the cloth, but even that sounds “mental extreme” to me.
Karl says they would use mat for the outer ply (usually over gel coat in a mold) because the random fibers hide better than the woven cloth on final finish. Woven cloth was only used on the inside/back of the molded parts he made while working for Callaway. I think I would rather fill weave with thickened epoxy and maybe have a little weave texture showing than have all of that extra weight and epoxy.
Wagondude/Bill, .
Tonight I made a couple of spacer blocks out of scrap pine to turn the plunge router into a flush cutting end mill. Just used the small Surform rasp and hand block to knock the corners off of the blocks so they wouldn’t dig into the foam. Double back taped them to the foot of the router making sure to leave enough space to span the guard blocking.
Simple to set the cutter flush using a straight edge (scrap block).
A few passes sliding back and forth, a little brush with the small sanding block, and everything is nice and flush.
In the meantime I started making up a couple of test blanks to help me decide which way to go on covering. On one edge I sanded a 3/4 radius to simulate the roof edge, and on the other I glued on a 1x2 piece of cedar. The cedar will get an 1/8 inch round over to simulate the door openings and hatch seal areas. I will also distress them some, apply some spackle and sand it fair to simulate my typical construction. Shown here with packing tape holding the cedar edges glued up with TB2 because it was easiest (hope it holds okay, should get plenty of air to cure in this configuration).
I’ll probably cut these in half and do at least four variations:
(A) Two plies 6 oz BID. I’m thinking 45 deg bias strips on the edges to aid wrapping, but no bias on the flat because in full scale I’d rather just roll out cloth along the trailer axis, rather than cut a bunch of overlapping bias pieces.
(B) Canvas applied over epoxy, wetted with same, no bias. May try laying part dry and wetting with squeegee.
(C) Canvas applied with TB2, wetted with epoxy, no bias.
(D) Canvas applied with TB2, wetted with latex paint, no bias.
I have a bunch of FG tape left over from another project, but it is not bias, so I’m not sure about using it, but it may be useful.
