Are Tankless water heaters water proof?
Postby atcNick » Wed Oct 14, 2015 11:35 am
Im wanting to mount a tankless water heater on an outside wall of my cargo trailer... Do I need to build an enclosure for it? Or will it handle rain and the elements ok?
Thanks,
nick
-Nick
atcNick
Re: Are Tankless water heaters water proof?
Postby dales133 » Wed Oct 14, 2015 12:50 pm
Pretty certain you can get outdoor instantaneous water heaters
dales133
Postby atcNick » Wed Oct 14, 2015 12:52 pm
Looking at something like this Eccotemp L5 Portable Tankless Water Heater and Outdoor Shower https://www.amazon.com/dp/B000TXOJQ4/re ... hwb0R26FTG
-Nick
atcNick
Postby dales133 » Wed Oct 14, 2015 1:52 pm
I read through all the info on amazon and it dosnt say one way or another but when you look at the description youd asume its ok mounted outside .
If it was me id maybe get a canvas cover made for it just to keep the worst of the weather out
dales133
Postby atcNick » Wed Oct 14, 2015 1:54 pm
Good idea dale. Thabks
-Nick
atcNick
Postby Padilen » Wed Oct 14, 2015 2:51 pm
Please post when you get yours working your likes and dislikes.
This pic is similar to what my plan is, but I have an old pressure washer frame I hope to use.
I believe it's a form member's.
Padilen
Postby lrrowe » Wed Oct 14, 2015 4:40 pm
My neighbor's heater is mounted outside his house.
Bob
lrrowe
Images: 439
Postby daveesl77 » Wed Oct 14, 2015 5:16 pm
My Triton 5L was mounted on the outside of my truck camper for a couple of years. Rain, snow, ice, sun, no problem. As far as I know, it is still working for the people that bought the camper. It can rust at the screws and such. Another hassle is that wind is the real enemy, blowing out the burner, so I built an aluminum surround for it that slipped on over bolts if needed. The top was not covered.
The 5L I have now rides inside the camper, but then attaches to the galley when I stop and pull out the galley boxes.
dave
daveesl77
Images: 273
Postby Padilen » Thu Oct 15, 2015 6:55 pm
daveesl77 wrote:My Triton 5L was mounted on the outside of my truck camper for a couple of years. Rain, snow, ice, sun, no problem. As far as I know, it is still working for the people that bought the camper. It can rust at the screws and such. Another hassle is that wind is the real enemy, blowing out the burner, so I built an aluminum surround for it that slipped on over bolts if needed. The top was not covered.
dave
Just ordered one!
Padilen
Postby Socal Tom » Fri Jun 19, 2020 9:47 pm
I have mine in a box that opens up. You should know that it can not be allowed to freeze with water in it. It will destroy the heat exchanger. They have a drain valve, but I've heard rumors of people that drained them but freezing still go them.
Socal Tom
Postby PCO6 » Sat Jun 20, 2020 6:58 am
I store my Eccotemp L5 inside my trailer when travelling and mount it on the side when camping. It has seen some rain without any problems. Being portable I just drain it and take it indoors in the winter.
PCO6
Postby dbhosttexas » Wed Aug 11, 2021 2:17 pm
Youtuber Jax Austin had a failure that he attributed to it being mounted outdoors on his Skoolie.
https://youtu.be/Hde8WvF7Mqk
But if you look at time index :50 you can clearly see he allowed the batteries to fail and leak in the battery compartment. FWIW that fault is likely recoverable.
My plan is even though they are likely water resistant / proof enough... why take undue chances with it? Not to mention reduce the risk of theft, and store it / mount it inside a plastic weatherproof gear box like a Pelican box, or for a MUCH lower cost a Monoprice box... Or just go cheaper and do what my cheap tail plans on doing. Haul it IN the rig, and then in camp hang it from the campers side and quick connect the fittings for gas and water and have at it...
dbhosttexas
Images: 29
