How to clean aluminum windows?
Important Information and Stickies...
(Threads with essential information about building teardrops)
Postby vitya-velik » Thu Dec 31, 2015 2:11 pm
How would I clean this aluminum window that i got?
vitya-velik
Re: How to clean aluminum windows?
Postby dales133 » Fri Jan 01, 2016 8:31 pm
Silvo polish or something similar after a good soapy wash i recon would work.wiping it down with
White spirits or shellite wouldnt hurt either.
dales133
Postby afreegreek » Sat Jan 02, 2016 11:56 pm
a
afreegreek
Postby Tomterrific » Sun Jan 03, 2016 10:34 am
You will never get it quite the way you want it. I had an old jalousie window given to me for my trailer. The aluminum corrosion was worse than what I see on your window. I used a green Scotchbrite sponge and etching wheel cleaner. The brand is Eagle to be used on bare aluminum wheels, not painted. The etching wheel cleaner contains phosphoric acid. This will brighten the mill finish but the dark pitted areas are too deep to remove.
The best comment was a guy asking when it was built. I said last year. No, no, he said, when was it originally built. He thought it was a vintage camper I restored. :-)
Tomterrific
Return to Essential Information about building teardrops
