Ductless Mini-Split Systems A/C
Re: Ductless Mini-Split Systems A/C
Postby dms2871 » Sun Jan 31, 2016 11:27 pm
Shadow Catcher wrote:All of the systems I see here are expensive and too big for a tear, this can be done for less than $200 and less than 50# easily replaceable.
80999
I really didn't want to penetrate the side or front of the td
dms2871
Postby Shadow Catcher » Mon Feb 01, 2016 8:39 pm
I did not either but the marine deck ports are easy and water proof.
79675
The big advantage to this is it can be left at home and was cheap to set up.
Postby dms2871 » Tue Feb 02, 2016 1:35 pm
Shadow Catcher wrote:I did not either but the marine deck ports are easy and water proof.
79675
how is it routed inside did you insulate supply and return on the inside?
dms2871
Postby OverTheTopCargoTrailer » Sun Feb 07, 2016 5:05 pm
While I agree Shadow Catcher has the best low cost solution but, can also tell you the following.
An "INVERTER - WITH HEAT PUMP would work from -5 to 118F heating and cooling. It could run on a pure sine 1000 watt honda generator & a 1,000 watt PSW morning star inverter and it can effectively heat or cool an area as small as 100 cubic feet. 5 X 6 x 3ft . It can be operated with a few solar panels and my system on a 7 x 18 trailer averages 165 watts @85F exterior cooling the interior to 72F. At 100 F exterior it climbs to about 250 watts per hour.
So there are many other factors to consider, shadow catchers system is great cooling only between 75-100F. The mini split does heating & cooling -5F to 115F using very little energy.
Cheers ottct
Users browsing this forum: No registered users and 25 guests
