I got more work done yesterday! I managed to get my doors cut out, and profiles sanded to match perfectly. I customized the Kuffel Creek door plans to make them a little taller and wider because I am what you would call a "big guy"!
jkidd6339 wrote:Looks like you on your way. Have fun with it. Good work.
Ragonk wrote:Brian,
Thanks for the advice. I plan to do separate wiring. For the 12 volt, I plan to find a 6 circuit fuse box and wire it up using LED lights and a Fantastic Fan, and maybe one 12v power outlet (to charge a phone if off grid somewhere). For the 110, I guess I'll start with a Home Depot breaker box an outlet in the cabin (laptop, DVD player, or to charge phone), 3 in the galley (one for the microwave) and one in the tongue box where I plan to put an ac unit. Do you know if I can just use a battery charger while at a camp site to charge battery while I'm using the lights or Fantastic Fan? I already have a Schumacher XM1-5 Maintainer 1.5-Amp that I bought last year to charge a car battery. That way I don't have to purchase a converter, and all that goes with it. I'm trying to keep it simple too, this electrical part of the build is testing my sanity LOL!
Gunguy05 wrote:Yeah. That should work. That is my plan anyways.
A fantastic fan only draws about 3 amps at max speed.. and if you are using LED lights, they draw very little. Invest in a good battery ( We bought an AGM 100 Ah). It was 200 bucks, but it should last a while and holds a charge, and doesn't off gas, so we can store it in a confined space.
Checkout this, if you haven't already, I have seen quite a few of these used, I think this is what our next one will be http://www.amazon.com/Blue-Sea-Systems- ... B000THQ0CQ
Good luck and keep us posted.
Ragonk wrote:Gunguy05 wrote:Yeah. That should work. That is my plan anyways.
Thanks Brian! I really like that block from the link you posted. I'll probably go with that one. I'll order in the morning and then run to Home Depot to get the rest of the wiring supplies.
Thanks again
Gunguy05 wrote:We spent a great deal of time going over the electrical plan on our first one. I'm happy with they way it turned out, but I think we might have overthought and overengineered it. I saw one at a TD gathering a while back that was both 12 and 120, and it was much simpler. It's amazing to me how much thought goes into such a small space, only to be step back later and think "why did I do all that"???
Ragonk wrote:One more question... Is it necessary to use stranded Romex for the 110volt? I already bought 12/2 Romex designed for kitchen and bathroom use...
Thanks!
Kevin
