Alaskan Benroy
Alaskan Benroy
Postby ratrod71 » Sat Apr 16, 2016 6:13 pm
Working on the hatch latches today. Useful tips! 1. I drilled a perfectly straight hole through a small block of 2x4. I then clamped the 2X4 to the hatch and used that as my pilot to drill a straight hole through the hatch. 2. I used a step drill to open up the hole where the t-handle screws to the outside. The t-handle has a step in the mounting surface that requires the hole to be enlarged. Happy building, Bryan
Alaskan Benroy build journal: viewtopic.php?f=50&t=61738
ratrod71
Alaskan Benroy
Postby ratrod71 » Sat Apr 23, 2016 12:39 pm
Finished installing the inner hatch trim this morning. Happy building, Bryan
ratrod71
Re: Alaskan Benroy
Postby KCStudly » Sun Apr 24, 2016 9:06 am
You are doing some nice clean work there! Looking great! :thumbsup: :applause:
Re: Alaskan Benroy
Postby ratrod71 » Sun Apr 24, 2016 10:33 am
KCStudly wrote:You are doing some nice clean work there! Looking great! :thumbsup: :applause:
Thank you. I put the outer hatch trim on, and permanently mounted both sections of the hurricane hinge yesterday also. Pictures to follow soon. Bryan
ratrod71
Alaskan Benroy
Postby ratrod71 » Sun Apr 24, 2016 6:05 pm
Got the outer hatch trim installed and mounted the hatch. Happy building, Bryan
ratrod71
Re: Alaskan Benroy
Postby TheOtherSean » Sun Apr 24, 2016 6:25 pm
Very nice. It looks like you're getting pretty close to completion.
TheOtherSean
Images: 111
Re: Alaskan Benroy
Postby ratrod71 » Sun Apr 24, 2016 7:24 pm
TheOtherSean wrote:Very nice. It looks like you're getting pretty close to completion.
I am so close now I can hardly belive it. Literally just a few more hours of time and it will be done. Attached photo is of the gray vinyl insert molding trim I used, and of the hurricane hinge detail. Happy building, Bryan
ratrod71
Re: Alaskan Benroy
Postby tony.latham » Sun Apr 24, 2016 8:37 pm
I can't wait and see a pic of that babe hitched up and parked out in the birch trees.
Re: Alaskan Benroy
Postby ratrod71 » Sun Apr 24, 2016 9:20 pm
tony.latham wrote:I can't wait and see a pic of that babe hitched up and parked out in the birch trees.
Soon my friend, soon. Speaking of birch trees, we got our leaves today. Everything is instantly green. Very mild winter. We are very early for "Greenout".
ratrod71
Re: Alaskan Benroy
Postby hartk1213 » Mon Apr 25, 2016 8:52 pm
Looking great man keep up the good work
I just updated mine you should take a look if you can
Sent from my SM-N920P using Tapatalk
hartk1213
Alaskan Benroy
Postby ratrod71 » Wed Apr 27, 2016 10:41 pm
I am on the final stretch. Installed the hatch strikers tonight. Hatch latches beautifully. I am going to take off the dang white plastic protective cover this weekend to see what it finally looks like. Very eager! Bryan
ratrod71
Re: Alaskan Benroy
Postby hartk1213 » Wed Apr 27, 2016 10:57 pm
Looks great I love the Orange fenders man
hartk1213
Re: Alaskan Benroy
Postby Redneck Teepee » Wed Apr 27, 2016 11:07 pm
Looking Good Bryan! Just on the curious side as to what your going to use to hold the galley hatch in the up position with.....prop rod's or gas spring's?
Looks like you got er ready for some spring and summer fun.........Great job! And will look great behind that 37 Ford Coupe :thumbsup: :thumbsup: :thumbsup: ........Larry
Redneck Teepee
Images: 21
Re: Alaskan Benroy
Postby ratrod71 » Wed Apr 27, 2016 11:29 pm
Redneck Teepee wrote:Looking Good Bryan! Just on the curious side as to what your going to use to hold the galley hatch in the up position with.....prop rod's or gas spring's?
Still scratching my head over what I am going to use for props. I already have the mechanical sliding type, and the stainless spring type, and I still may choose the gas struts. This will be my last critical decision. Bryan
ratrod71
Re: Alaskan Benroy
Postby ratrod71 » Wed Apr 27, 2016 11:31 pm
hartk1213 wrote:Looks great I love the Orange fenders man
Thanks! The Hugger Orange really pops when you see it in person. I have always liked bright colors. Bryan
ratrod71
