by Andrew Herrick » Mon Oct 24, 2016 12:31 am
I know it's an old thread ... but in case anyone is building a super simple electrical system and doesn't want/need 30-amp connector ...
The NOCO Genius GCP1 installs in about 5 minutes with a 2-inch hole saw. Only good for 15-amp power, but it eliminates any need for wire splicing or exterior waterproofing.
It's nothing fancy. No real security or twist-lock features or in-use enclosure. It's definitely not a one-size-fits-all solution. But if you want cheap, fast and easy, it's the best I've found. Good luck!
