Good Day everyone,
My name is Rob and I am a new member of the forum, but a long time learker without an account by just google searching. I finally signed up for an account this past week to share with everyone a build that I started the beginning of March. It is about 90% built as I write this but wanted to start adding a little until it was completed. The ideas on here and other forums, blogs,and personal websites have helped me put my camper together. So I wanted to put something out there to help others when they decide to make one.
The search for a small camper started over 2 years ago when my wife and I started talking about camping in a pop up when we were younger with family. We really enjoyed it and were thinking it'd be great to do it again. We were thinking of something small and light that we could tow with my 2001 Ford Focus. In that time frame I also purchased a newer car, a 2011 Subaru Forester and it also has a greater towing capacity than the Focus. But we would still like the option to tow with the focus also since I still own that also. While searching for small light campers I came up with a lot of teardrops, many of them homemade and there were so many unique ideas. Over the last two years nothing happened besides some casual conversation about building one and some random searches, which sparked more conversation with no camper being built.
Building Begins With the not so good winter for snowboarding on the east coast upon us and no immediate projects going on inside the house for the winter we decided to start building the tear drop in March 2016. I decided to stop snowboarding this year early since the conditions were not the greatest and put the money into making the tear drop for this summer, with the hopes of having the bugs worked out and do some winter camping with it as well as snowboard trips.
I had no drawings to go by and just a general plan in my head. So the build started with just that.
We already have an Aluma, aluminum trailer rated for 2000lbs that I use for hauling my motorcycles and for doing work around the house. It only weighs 300lbs with the bifold gate off. This gives me a good base to work with. I did not want to make this trailer dedicated to the tear drop so the idea was to make a slide on, slide off tear drop camper for the trailer. This way we can just store the teardrop on its "parking platform" in the back yard by the shed and still have use of Aluminum trailer. I also won't have to have another registered trailer in the yard. We will see if this will become and inconvenience or not as time goes on.
Here is the Aluma being used with the focus and the XR650L
- Focus
- IMG_3124.JPG (148.95 KiB) Viewed 2228 times
The next thing so do was pick up some material and start building a base that would serve as the foundation of the teardrop. We knew we wanted some storage below the floor but were not sure how much. I also wanted the ability for the tear drop to be able to be slid back 1.5'-2.0' on the trailer so that I could put an aluminum motorcycle carrier on the front of the trailer by the tongue to carry my dual sport. By sliding the trailer back the overall length of the trailer would now be 9.5'-10'. The weight of the galley would hopefully offset the extra weight of the 300 lb bike towards the front of the trailer reducing tongue weight. The heaviest art of the teardrop would be from the wheels back especially once it was overhanging the back of the trailer. This was all in theory since we had not even started building yet. The closest I could simulate this was take my 300lb lawn roller and put it in the trailer in the front by the tongue and then put my riding mower which weighs close to 550 lbs on after that. Sure enough, the rider balanced off the tongue weight of the 300 lb roller with it all the way to the back of the gate. So it appears this might be feasible. With nothing built yet and some ideas on the table I still have to figure out how I will make it easily removable. I have some ideas but will work on that as the build goes along. Time to get started.
This first part of the build was making the base. Since we wanted storage and I needed strength incase I slid back the trailer, we decided upon using three 2x10's as the main floor joist. The base would be 1/2 inch plywood and the top/floor would be furniture grade birch plywood. So that the camper could be slid on and off there were three pieces of composite decking added to the 1/2 inch plywood on the bottom to act as skids for the camper to slide on. Anytime I have used composite decking I am amazed at how easily it slides since it it mostly plastic.
With the base built it was time to come up with a profile of the walls. I sketched 3-4 arcs on the sheet of plywood and we chose the one that seemed to be the profile we liked. With the profile picked I cut one of the 1/4 inch ply's so that we could see what is looked like. It wasn't perfect so we changed the arcs a bit and found the profile we liked. The walls will be built with 1/4" plywood on the inside and outside and 1.5" of foam insulation in the living space, with 1x2's used as studs throughout. Here is a picture of the base and the walls.
- IMG_6306 small.jpg (170.87 KiB) Viewed 2228 times
- IMG_6314 small.jpg (166.21 KiB) Viewed 2228 times
More to come. In the meantime I need to figure out what to do about the roofing and support.
